Zoneminder on Centos 5.4 with Panasonic BL-C131A
Posted: Sun Feb 28, 2010 9:27 pm
My zoneminder set up started acting wierd today and I can't pin down the issue. While I have not changed anything on the zoneminder side I have upgraded the Panasonic firmware to Version 3.52R01.
I get the following error in my logs when attempting to do mo-cap
Been trying to figure it out all day. Re-started the VM, restarted the router, checked the network connection from the VM to the camera. Checked the camera's output. Everything has been normal.
Any ideas what is happening here?
Thanks.
Feb 28 16:17:43 cctv zmc_m1[5618]: INF [Starting Capture]
Feb 28 16:17:43 cctv zmc_m1[5618]: ERR [Select timed out]
Feb 28 16:17:43 cctv zmc_m1[5618]: ERR [Unable to read header]
Feb 28 16:17:43 cctv zmc_m1[5618]: ERR [Unable to get response]
Feb 28 16:17:43 cctv zmc_m1[5618]: ERR [Failed to capture image from monitor 1 (0/1)]
Feb 28 16:17:43 cctv zmdc[4074]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Feb 28 16:17:53 cctv zmdc[4074]: INF [Starting pending process, zmc -m 1]
Feb 28 16:17:53 cctv zmdc[5645]: INF ['zmc -m 1' started at 10/02/28 16:17:53]
Feb 28 16:17:53 cctv zmdc[4074]: INF ['zmc -m 1' starting at 10/02/28 16:17:53, pid = 5645]
Feb 28 16:17:53 cctv zmc_m1[5645]: INF [Debug Level = 0, Debug Log = <none>]
Feb 28 16:17:53 cctv zmc_m1[5645]: INF [Starting Capture]
Feb 28 16:17:53 cctv zmc_m1[5645]: ERR [Select timed out]
Feb 28 16:17:53 cctv zmc_m1[5645]: ERR [Unable to read header]
Feb 28 16:17:53 cctv zmc_m1[5645]: ERR [Unable to get response]
Feb 28 16:17:53 cctv zmc_m1[5645]: ERR [Failed to capture image from monitor 1 (0/1)]
Feb 28 16:17:53 cctv zmdc[4074]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Feb 28 16:17:54 cctv zmdc[4074]: INF [Command 'zmc -m 1' removed from pending list at 10/02/28 16:17:54]
Feb 28 16:17:54 cctv zmdc[4074]: INF ['zma -m 1' stopping at 10/02/28 16:17:54]
Feb 28 16:17:54 cctv zma_m1[5601]: INF [Got signal 15 (Terminated), exiting]
Feb 28 16:17:54 cctv zmdc[4074]: INF ['zma -m 1' exited normally]
Thanks.
