Kernel Panic
Posted: Wed Mar 03, 2010 2:16 pm
List, I have Centos 5,4 64 Bits + two plates kodicom 8800 + 12 Chambers. PALN The system works, but every 5 or 6 days, I have a problem that stands the PC and panic appears to me kernel. Also planata the PC if I only qualify the 16 chambers and I have myself working 10. There everything stands
Breadfruit them passage like this formed
Pentiun IV - 2 GB RAM - STA 500 GB
/etc/modprobe.conf
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102,102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4,4,4,4,4,4,4,4,4 coring=1 full_luma_range=1 chroma_agc=1 combfilter=1 autoload=0 triton1=0 vsfx=0
alias eth0 e100
/etc/sysctl.conf
kernel.shmall = 324403200
kernel.shmmax = 324403200
camaras:
320*240
PAL
YUV422P
V4L2
25 FPS
Buffers:
80
25
10
60
1000
1
Lista,, tengo Centos 5.4 64 Bits + dos placas kodicom 8800 + 12 Camaras. PALN
El sistema funciona , pero cada 5 o 6 dias, tengo un problema que se planta la pc y me aparece kernel panic.
Tambien se planata la pc si habilito las 16 camaras y solamente tengo funcionando 10. Ahi se planta todo
Aca les paso como esta configurado
/etc/modprobe.conf
alias eth0 e100
/etc/sysctl.conf
camaras:
320*240
PAL
YUV422P
V4L2
25 FPS
Buffers:
80
25
10
60
1000
1
/etc/modprobe.conf
alias eth0 e100
/etc/sysctl.conf
camaras:
320*240
PAL
YUV422P
V4L2
25 FPS
Buffers:
80
25
10
60
1000
1
/etc/modprobe.conf
alias eth0 e100
/etc/sysctl.conf
camaras:
320*240
PAL
YUV422P
V4L2
25 FPS
Buffers:
80
25
10
60
1000
1
