Chubb DVR Remote Camera URL
jayman
Post by jayman »
I have a Chubb DVR system and I can get the images using the URL
http://x.x.x.x/dsr-cgi/GetDSRImage.cgi? ... word=12345&
Is there anyway I can put these into Zoneminder using the above URL. I've tried multiple ways but I can never get an image to show up.
Thanks.
jayman
Post by jayman »
no one can help?
jameswilson
Post by jameswilson »
if they are normal jpegs then yes
just strip the ip and use the rest as the path
and use the ip only, ie no http.
ensure that you set the image monitor to match exactly the jpeg
and ensure you have enough shared mem to handle the size of image returned
James Wilson
jayman
Post by jayman »
Ahhhh the Remote Host Path field is not setup to be long enough to put in the entire URL.
It gets cut off at: /dsr-cgi/GetDSRImage.cgi?camera=1&width=320&height=240&username=
Is that something I can fix myself?
jayman
Post by jayman »
Ahhhhh http://www.zoneminder.com/forums/viewto ... emote+path
Just didn't search for the right thing.
