I tried to search a number of places to find out about these two cameras and Zoneminder - I found a but about a number of different Trendnet cameras and other branded versions of this same camera, but was unable to find anything concrete on how to get it working.
After some poking around a bit, I can confirm these two cameras work fine in Zoneminder at 22 - 25 FPS. I had to increase my shared memory to 128MB to get these cameras to work at the 640x480 resolution.
Settings are:
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: <username>:<password>@x.x.x.x
Remote host Port: 80
Remote Host Path: /cgi/mjpg/mjpg.cgi
Capture Width: 640
Capture Height: 480
Trendnet TV-IP110 & TV-IP110W working
Microcenter currently has the non-wireless models for $79 less $20 mail-in rebate. Mine works fine with the posted settings.
Edit: gonna connect it to my network through some linksys ple200 powerline ethernet adapters.
edit2: summabitdge not liking the linksys ple200's. seems to get a dhcp address but no connectivity.
Re: Trendnet TV-IP110 & TV-IP110W working
Hi Inaba
What is the firmware version which you are running on the IP-TV110?
I am still not able to make it work
P.
P.
TV-IP110 working
I also have had success with the Trendnet TV-IP110 using zm 1.24.2 on ubuntu 10.04 LTS (lucid).
Critical to making this work was setting the proper shared memory size of 132 MB!! See the zoneminder installation instructions for 10.04.
Firmware version is 1.1.0 build 60.
TV-IP110W
Just got one of these configured with ZM 1.24.2/Ubuntu 10.10. Very nice and fast with about a ~28 FPS connection. This is in a setup of 8 analogue DVR card cams and #3 IP cams (Panasonic and Foscam being the other IP cams). Took all of 5 minutes to configure.
I'm impressed; purchased the TV-IP110W for $69 with free shipping. Decent HW build and very quick IE/FF interface.
