NX Pro Webcam + Fedora 12 shows no image
andyph666
Post by andyph666 »
Hi there. I have installed fedora 12 + amahi. The can access the zoneminder console but the /dev/video0 is red. It changes to orange when I change a setting and press ok. Then it changes back to red again. I installed ffmpeg as well. It works with the cheese webcam program.
I'm running fedora 12 with 2.6.32.9 kernel.
Installed zoneminder from yum.
Editted the config to delete the line that I had to delete.
Imported the .sql file to the mysql database.
I can access console fine but cannot view the webcam.
The settings I am using are:
320 x 240
Function: monitor
Pal
RGB24
03/10/2010 18:30:44.038254 zmdc[3878].INF [Starting pending process, zmaudit.pl -c]
03/10/2010 18:30:44.039530 zmdc[3878].INF ['zmaudit.pl -c' starting at 10/03/10 18:30:44, pid = 4236]
03/10/2010 18:30:44.271831 zmdc[3878].ERR ['zmaudit.pl -c' exited abnormally, exit status 9]
03/10/2010 18:30:44.458076 zmdc[3878].ERR ['zmc -d /dev/video0' exited abnormally, exit status 11]
03/10/2010 18:32:41.162239 zmdc[3878].INF [Command 'zmc -d /dev/video0' removed from pending list at 10/03/10 18:32:41]
03/10/2010 18:32:41.331304 zmdc[3878].INF ['zmc -d /dev/video0' starting at 10/03/10 18:32:41, pid = 4303]
03/10/2010 18:32:41.499592 zmdc[3878].WAR [Can't find process with command of 'zma -m 8']
03/10/2010 18:32:41.797178 zmdc[3878].ERR ['zmc -d /dev/video0' exited abnormally, exit status 11]
03/10/2010 18:32:41.797502 zmdc[3878].INF [Starting pending process, zmc -d /dev/video0]
03/10/2010 18:32:41.798432 zmdc[3878].INF ['zmc -d /dev/video0' starting at 10/03/10 18:32:41, pid = 4310]
03/10/2010 18:32:42.259274 zmdc[3878].ERR ['zmc -d /dev/video0' exited abnormally, exit status 11]
