I'm not good at coding and the script might even hurt your camera. I played with the script an stuff from this post
http://www.zoneminder.com/forums/viewto ... ht=control
I messed around with it and it really looks bad, but it moves my cam. Hardcoded the video-device to my video1.
So here is what it looks like:
# ZoneMinder QuickcamSphere Control Protocol Module, $Date: 2009-02-08
# Copyright (C) 2009 Bokusouchi
# This module contains the implementation of the QuickcamSphere camera control
# protocol
package ZoneMinder::Control::QuickcamSphere;
use 5.006;
use strict;
use warnings;
use IO::Handle;
use File::Basename;
use File::Find;
# These are the elements you can edit to suit your installation
use constant DBG_ID => "QuickcamSphere"; # Tag that appears in debug to identify source
use constant DBG_LEVEL => 0; # 0 is errors, warnings and info only, > 0 for debug
require ZoneMinder::Base;
require ZoneMinder::Control;
# QuickcamSphere Control Protocol
use Time::HiRes qw( usleep );
use constant SYNC => 0xff;
use constant COMMAND_GAP => 100000; # In ms
my $untainted_device = 'video1';
my $device_temp_file = '/tmp/dynctrl.tmp';
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
$self->loadMonitor();
$self->where_am_i();
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub moveRelUp
my $self = shift;
my $params = shift;
my $tiltstep = $self->getParam( $params, 'tiltstep' );
Debug( "Step Down" );
my $pan_min=$self->{Monitor}->{MinPanRange};
my $pan_max=$self->{Monitor}->{MaxPanRange};
my $tilt_min=$self->{Monitor}->{MinTiltRange};
my $tilt_max=$self->{Monitor}->{MaxTiltRange};
my $pan_cur=$self->{Monitor}->{pan_cur};
my $tilt_cur=$self->{Monitor}->{tilt_cur};
my $focus_cur=$self->{Monitor}->{focus_cur};
my $panstep=0;
if ($tilt_cur + $tiltstep > $tilt_max) {
$tiltstep = $tilt_max - $tilt_cur;
Debug( "panstep=$panstep tiltstep=$tiltstep ,before untaint" );
my $untaint1="0";
my $untaint2="0";
($untaint1)="$panstep"=~ /^(-?[0-9]+)$/;
Debug ("untaint1= $untaint1");
($untaint2)="$tiltstep"=~ /^(-?[0-9]+)$/;
Debug ("untaint2= $untaint2");
$panstep=$untaint1;
$tiltstep=$untaint2;
my $untainted_device="video1";
#($untainted_device) =$self->{Monitor}->{uvcdynctrl_device}=~ /^([\w.</Debug>{Monitor}->{pan_cur}=$pan_cur;
$tilt_cur=$self->{Monitor}->{tilt_cur}=$tilt_cur;
my $device_temp_file=$self->{Monitor}->{device_temp_file};
my $fh=IO::Handle->new();
Debug( "device_temp_file=$device_temp_file");
CORE::open($fh,">","$device_temp_file") || die("Cannot open $device_temp_file");
CORE::print($fh "$pan_cur:$tilt_cur:$focus_cur");
CORE::close($fh);
Debug( "Moving to $pan_cur,$tilt_cur \n" );
$tiltstep = $tiltstep * 64 ;
$panstep = $panstep * 64 ;
Debug( "real_panstep = $panstep real_tiltstep = $tiltstep\n" );
if ( $tiltstep == 0 )
CORE:system("/usr/bin/uvcdynctrl" ,"-d", $untainted_device ,"-s","Tilt (relative)" ,"--","$tiltstep") ;
if ( $panstep == 0 )
CORE:system("/usr/bin/uvcdynctrl" ,"-d",$untainted_device ,"-s","Pan (relative)" ,"--","$panstep") ;
if ( $tiltstep != 0 )
CORE:system("/usr/bin/uvcdynctrl" ,"-d", $untainted_device ,"-s","Tilt (relative)" ,"--","-$tiltstep") ;
CORE:usleep (400);
if ( $panstep != 0 )
CORE:usleep (400);
sub moveRelDown
my $self = shift;
my $params = shift;
my $panstep=0;
my $untaint1="0";
my $untaint2="0";
$panstep=$untaint1;
CORE::close($fh);
CORE:usleep (400);
CORE:usleep (400);
sub moveRelLeft
my $self = shift;
my $params = shift;
my $tiltstep=0;
my $panstep = $self->getParam( $params, 'panstep' );
Debug( "panstep=$panstep" );
Debug( "Step Left" );
Debug("pan_max=$pan_max");
Debug("pan_min=$pan_min");
if ($pan_cur + $panstep > $pan_max) {
$panstep = $pan_max - $pan_cur;
Debug( "Hitting the limite --> recalculating panstep" );
my $untaint1="0";
my $untaint2="0";
$panstep=$untaint1;
# ($untainted_device) =$self->{Monitor}->{uvcdynctrl_device}=~ /^([\w.</Debug>{Monitor}->{pan_cur}=$pan_cur;
CORE::close($fh);
Debug( "real_panstep = $panstep reial_tiltstep = $tiltstep\n" );
CORE:usleep (400);
CORE:usleep (400);
sub moveRelRight
my $self = shift;
my $params = shift;
my $tiltstep=0;
my $untaint1="0";
my $untaint2="0";
$panstep=$untaint1;
CORE::close($fh);
CORE:usleep (400);
CORE:system("/usr/bin/uvcdynctrl" ,"-d",$untainted_device ,"-s","Pan (relative)" ,"--","-$panstep") ;
CORE:usleep (400);
sub moveRelUpLeft
my $self = shift;
my $params = shift;
sub moveRelUpRight
my $self = shift;
my $params = shift;
sub moveRelDownLeft
my $self = shift;
my $params = shift;
sub moveRelDownRight
my $self = shift;
my $params = shift;
sub focusConNear
my $self = shift;
my $params = shift;
Debug( "Focus Near" );
sub focusConFar
my $self = shift;
my $params = shift;
Debug( "Focus Far" );
sub presetClear
my $self = shift;
my $params = shift;
my $preset = $self->getParam( $params, 'preset', 1 );
Debug( "Clear Preset $preset" );
sub presetSet
my $self = shift;
my $params = shift;
sub presetGoto
my $self = shift;
my $params = shift;
sub presetHome
my $self = shift;
my $params = shift;
# Debug("device= $self->{Monitor}->{ControlDevice}");
# $self->where_am_i();
# my @msg = ( 0x80|$self->{Monitor}->{ControlAddress}, 0x01, 0x06, 0x04, SYNC );
# $self->sendCmd( \@msg );
sub where_am_i
my $self = shift;
my $params = shift;
# We have a device ... where is it now?
Debug("n ::where_am_i:: ");
$self->{Monitor}->{MinPanRange}=-55,
$self->{Monitor}->{MaxPanRange}= 55,
$self->{Monitor}->{MinTiltRange}=-28,
$self->{Monitor}->{MaxTiltRange}= 24,
Debug("MinPanRange= $self->{Monitor}->{MinPanRange}");
Debug("MaxPanRange= $self->{Monitor}->{MaxPanRange}");
Debug("MinTiltRange= $self->{Monitor}->{MinTiltRange}");
Debug("MaxTiltRange= $self->{Monitor}->{MaxTiltRange}");
my $sym_device_basename=File::Basename::basename($self->{Monitor}->{ControlDevice});
Debug("sym_device_basename= $sym_device_basename");
#my $device_temp_file="/tmp/"."$sym_device_basename".".current";
Debug ( "grrr device_temp_file= $device_temp_file \n" );
$self->{Monitor}->{device_temp_file}=$device_temp_file;
CORE::open($fh, "$device_temp_file") || Debug ("Could not open $device_temp_file");
my $diamond_handle=$fh;
my ($pan_cur,$tilt_cur,$focus_cur)=CORE::split(/:/,$diamond_handle);
CORE::close($fh);
Debug ( "Currently at $pan_cur,$tilt_cur,$focus_cur" );
$self->{Monitor}->{pan_cur}=$pan_cur;
$self->{Monitor}->{focus_cur}=$focus_cur;
Debug ( "Currently(monitor object) at $self->{Monitor}->{pan_cur}, $self->{Monitor}->{tilt_cur},$self->{Monitor}->{focus_cur}" );
#first we deduce the real device name
my $real_device="video1";
#$real_device=File::find::readlink("$sym_device");
#$real_device=CORE::readlink("$self->{Monitor}->{ControlDevice}");
Debug ( "real_device= $real_device" );
my $tainted_device=File::Basename::basename($real_device);
Debug ( "tainted_device= $tainted_device" );
$self->{Monitor}->{uvcdynctrl_device}=$tainted_device ;
#my uvcdynctrl_device="glop";
#$uvcdynctrl_device) = $tainted_device=~ /^([\w.<>\/,"=]+)$/;
#Debug ( "uvcdynctrl_device= $uvcdynctrl_device \n" );
#srand( time() );
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
use ZoneMinder::Database;
blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Bokusouchi
=head1 COPYRIGHT AND LICENSE
Copyright (C) 2009 bokusouchi
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
Set the Cam as Controllable (remember to to check OPT_CONTROL in Option/System). click EDIT beside 'Control Type', then 'Add new control'. Name it to QuickcamSphere (although you can name it to whatever you want), Type Local, Protocol QuickcamSphere (this is important, name it exactly like that) Dont check Can Wake, Can Sleep, Can Reset. On the Move Tab check Can Move and Can Move Relative. On the Pan-Tab Check Can Pan, Min Pan Range -7000, Max Pan Range 7000, Min Pan Step 10 and Max Pan Step 10. Other stuff there unchecked. On the Tilt-Tab Check Can Tilt, Min Tilt Range -2500 and Max Tilt Range 2500, Min Tilt Step 10 and Max Tilt Step 10. everything else unchecked. Dont touch the other Tabs. Hit Save, close the Control Capabilities window. On your Monitor click Buffer-Tab (or any other) and back to Control zu select your new Control Type.
Hit Save. Almost done
When vieving the monitor, there is the 'Control' Link. hit that, you get some arrows. Try them, it should work.
AS I SAID. NO WARRANTY. Of course you have to habe libwebcam and uvcdynctrl as described here http://www.quickcamteam.net/software/libwebcam
get this working on the commandline first make sure it works there with e.g.
uvcdynctrl -d video1 -s "Tilt (relative)" -- 900
perl -w /usr/share/perl5/ZoneMinder/Control/QuickcamSphere.pm
zmcontrol[19435].INF [Control server 7/QuickcamSphere.pm starting at 10/03/11 11:31:16]
03/11/10 11:31:36.412291 zmcontrol[19434].FAT [Can't connect: No such file or directory]
Well, i guess thats it. Have fun feel free to ask when having Problems. Thanks to the whole Zomeninder-Team for their great Software.
Maybe someone with Knowledge in Perl can somehow clean up the mess i made in the module
Regards
Michael
