Remove event after 7 days
Fabbbio
Post by Fabbbio »
I want to know I can remove event older than 7 day automaticly. Because , for the privacy law, I can't store image more than week.
bb99
Post by bb99 »
Bring up the ZM console, single click the filters button and design a filter that does exactly what you want it to do. don't forget to save it and check the run filter in the background box.
VF
Filter
Post by VF »
Ciao,
you need to create a Filter like this:
date less than "-7days" and archive status equal to "unarchived only" -> DELETE ALL MATCHES
in this way you can program the ZM to automatically delete the unarchived events, older than 7 days.
Remember to set the "run filter in background" check box, when saving!
Flasheart
Post by Flasheart »
Greater than 7 days, no?
Flav
Post by Flav »
Or more than "Last week", unarchived, del all
