Debian: Events with zero duration and no image in zone defin
peterthevicar
Post by peterthevicar »
Philip you are a super hero of the first order! What a wonderful piece of software!
I've just installed ZM onto a Debian (Sid) system.
I took quite a while to sort out the configurations but I thought this particular part might be worth posting for
others trying the same thing.
The underlying problem is that in Debian apache runs as user 'www-data' by default. This means ZM can't write into its images or events directories. A simple fix is to change all the zm files owned by apache to be owned by www-data:
cd /var/www/html/zm
find . -user apache | xargs chown www-data:
I'm now up and running looking at pictures of a suspicious me typing at the keyboard.
Thank you Philip!
Next step is to get the system installed at church (since we last spoke we have had a burnt out wheely-bin, paint on the windows and a smashed letter box - all in a fortnight!)
My log of what I've done to install the system is at www.salisburys.net/zoneminderlog.html
HTH, Peter
