I'm attempting to watch and understand performance on my systems through graphing.
Obviously load goes up when I'm capturing more frames (or other things). But my goal is to create a history and graph it. I can then match this history against CPU load, memory consumption, disk growth, etc.
Does anyone have any pre-existing scripts to pull the FPS on each camera from out of the /var/log/messages file and log it RRD style? I've read about perl's File::Tail for taking just the new lines of a file but I think that's over my head for programming.
So, here's to hoping one of you has already created something like this.
And if not, I will eventually post my script/method when I find or create it.
RRDtool / Xymon / Hobbit script(s)
That's how I would have traditionally done this. But I'm afraid that if I do it that way I risk getting repeating values. Or missing a value. A constant tail should do the trick. Here's what I've come up with since I wrote the question:
Install Perl-POE (from rpm or from cpan).
Grab this perl code from the POE site:
http://poe.perl.org/?POE_Cookbook/Watching_Logs
Call it something. I called it 'ptail' per a recommendation I read on their site.
Then call it using your own shell script like so:
Now when I run it with the name of my camera as the argument I get the output I want.
At this point it appeared to be just shell coding. Which is something I'm good at.
But for some reason that I'm not yet able to determine, I can't redirect that output into a file that I specify. I've tried redirecting output after the last line in the script and I've tried redirecting output after the argument in the command line that I'm running. Neither worked. It would have no output as STDOUT or to the file I redirected to. I suspect it has something to do with how it is a "tail" without and end of the output.
...so I'm close already...
#!/usr/bin/perl -w
# http://poe.perl.org/?POE_Cookbook/Watching_Logs
use POE qw/Wheel::FollowTail/;
use strict;
$| = 1;
my $filename = $ARGV[0];
die "Usage: $0 <filename>\n" unless $filename;
die "$0: $filename: No such file or directory\n" unless -e $filename;
die "$0: $filename: Permission denied\n" unless -r $filename;
POE::Session->create(
inline_states => {
_start => sub {
$_[HEAP]->{wheel} = POE::Wheel::FollowTail->new(
Filename => $_[ARG0],
InputEvent => 'got_line',
ErrorEvent => 'got_error',
SeekBack => 1024,
$_[HEAP]->{first} = 0;
got_line => sub { print "$_[ARG0]\n" if $_[HEAP]->{first}++ },
got_error => sub { warn "$_[ARG0]\n" },
args => [$filename],
$poe_kernel->run();
#!/bin/bash
PERLSCR=/usr/local/scripts/ptail
CAMNAME=$1
$PERLSCR /var/log/messages | awk "/Capturing/ && /$CAMNAME/ {print \$12}"
[root@zmhost tmp]# ./fps.recording.sh Trendnet
19.23
19.23
18.77
19.23
Solved
I scrapped my previous method in perl and decided to make a few assumptions about the logs always being in the same order. So here's what I did to get this running on Xymon.
Placed a shell script in ~xymon/client/ext/ called fps.sh
#!/bin/bash
$BB $BBDISP "status $MACHINE.fps green `date`
cam1 : `tail -250 /var/log/messages | awk \"/Capturing/ && /Foscam/ {print \\$12}\" | tail -1`
cam2 : `tail -250 /var/log/messages | awk \"/Capturing/ && /CiscoPTZ/ {print \\$12}\" | tail -1`
cam3 : `tail -250 /var/log/messages | awk \"/Capturing/ && /Trendnet/ {print \\$12}\" | tail -1`
exit 0
Then add to ~xymon/client/etc/clientlaunch.cfg :
[fps]
ENVFILE /usr/lib64/xymon/client/etc/hobbitclient.cfg
CMD /usr/lib64/xymon/client/ext/fps.sh
LOGFILE $HOBBITCLIENTHOME/logs/fps.log
INTERVAL 3m
At this point you want to restart the client and make sure the xymon web server is showing the new column and data.
Now go into the server CLI and modify the /etc/xymon/hobbitserver.cfg and add this to the end of the TEST2RRD line: fps=ncv
Mine, with everything else as default looks like this:
TEST2RRD="cpu=la,disk,inode,qtree,memory,$PINGCOLUMN=tcp,http=tcp,
dns=tcp,dig=tcp,time=ntpstat,vmstat,iostat,netstat,temperature,apache,bind
,sendmail,mailq,nmailq=mailq,socks,bea,iishealth,citrix,bbgen,bbtest,bbproxy,
hobbitd,files,procs=processes,ports,clock,lines,ops,stats,cifs,JVM,JMS,HitCache,
Session,JDBCConn,ExecQueue,JTA,TblSpace,RollBack,MemReq,InvObj,snapmirr,snaplist,
snapshot,if_load=devmon,temp=devmon,fps=ncv
NCV_fps="cam1:GAUGE,cam2:GAUGE,cam3:GAUGE"
Now, setup the graphs in /etc/xymon/hobbitgraph.cfg. Add this stanza:
[fps]
TITLE FPS info
YAXIS FPS
DEF:cam1=fps.rrd:cam1:AVERAGE
DEF:cam2=fps.rrd:cam2:AVERAGE
DEF:cam3=fps.rrd:cam3:AVERAGE
LINE2:cam1#00CCCC:cam1 FPS
LINE2:cam2#FF0000:cam2 FPS
LINE2:cam3#FF00FF:cam3 FPS
COMMENT:\n
GPRINT:cam1:LAST:cam1 FPS \: %5.1lf%s (cur)
GPRINT:cam1:MAX: \: %5.1lf%s (max)
GPRINT:cam1:MIN: \: %5.1lf%s (min)
GPRINT:cam1:AVERAGE: \: %5.1lf%s (avg)\n
GPRINT:cam2:LAST:cam2 FPS\: %5.1lf%s (cur)
GPRINT:cam2:MAX: \: %5.1lf%s (max)
GPRINT:cam2:MIN: \: %5.1lf%s (min)
GPRINT:cam2:AVERAGE: \: %5.1lf%s (avg)\n
GPRINT:cam3:LAST:cam3 FPS \: %5.1lf%s (cur)
GPRINT:cam3:MAX: \: %5.1lf%s (max)
GPRINT:cam3:MIN: \: %5.1lf%s (min)
GPRINT:cam3:AVERAGE: \: %5.1lf%s (avg)\n
GRAPHS="la,disk,inode,qtree,files,processes,memory,fps,users,vmstat,
iostat,tcp.http,tcp,ncv,netstat,ifstat,mrtg::1,ports,temperature,ntpstat,apache,
bind,sendmail,mailq,socks,bea,iishealth,citrix,bbgen,bbtest,bbproxy,hobbitd,clock
,lines,ops,stats,cifs,JVM,JMS,HitCache,Session,JDBCConn,ExecQueue,JTA,TblSpace
,RollBack,MemReq,InvObj,snapmirr,snaplist,snapshot,devmon::1,if_load::1,temp"
And, obviously, everywhere that I have the "cam1" through "cam3" setup, you can keep adding cams in there. Don't forget to change the color in the graphing or it will get ugly down the road.
And I think that's all.
