Why do I get alarms continuously ? (Why were alarms started)
magix_ch
Post by magix_ch »
My system is continuously saving alarms, but I don't understand why...
Is there an easy way to see why an alarm was started ?
Thanks a lot !
Denis
kingofkya
Post by kingofkya »
it means you need to adjust your zm zones to remove sources of movement like trees. and/or you need to lower the zones sensitivity.
