Hi all,
Got ZM 124 up and running great on Ubuntu 9.04...
Is there anyway of making the ZM console accessible from something like www.staticip/anything instead of www.staticip ?
123 seemed to be fine with www.staticip/zm but when I went to 124 its now back to www.staticip
I want to move it off the root... if you know what I mean
Thanks in advance
Sq
Zm web address
use name virtual host in apache
use name virtual host in apache and you can have any name you want
that is the only way
Thanks for the replies guys, much appreciated..
antar, is there any chance you could elaborate a little for me? I've bee accessing apache thru webmin and played with the virtual host settings. At present zomeminder is on the default host. How would i set it up so i could have my website running on www.myip.com and zm on www.myip/zm?
diven, could you elaborate a little on what you posted too please ?
I understand I can have as many virtual hosts as I want within reason? Is this right? Just not too sure how to set things up.
Sorry guys I'm a zomeminder/Ubuntu newb
Sq
Sq
You should have a directory something like /var/www/htdocs which is your web server root. Add a directory named zm and put all the zm files in there.
Edit /etc/zm.conf to read:
# Path to ZoneMinder web files
ZM_PATH_WEB=/var/www/htdocs/zm
I don't use Ubuntu so I can't comment on the file structure or the default apache config but it should be similar.
A virtual host is for adding an additional hostname to your web server.
