Page 1 of 1
Zm web address
Posted: Thu Mar 18, 2010 2:09 am
by SquALeD
Hi all,
Got ZM 124 up and running great on Ubuntu 9.04...
Is there anyway of making the ZM console accessible from something like
www.staticip/anything instead of
www.staticip ?
123 seemed to be fine with
www.staticip/zm but when I went to 124 its now back to
www.staticip
I want to move it off the root... if you know what I mean
Thanks in advance
Sq
use name virtual host in apache
Posted: Thu Mar 18, 2010 2:00 pm
by antar
use name virtual host in apache and you can have any name you want
that is the only way
Posted: Thu Mar 18, 2010 5:21 pm
by diven
I accomplished that by modifying the /etc/zm.conf file. Just make sure that httpd.conf is configured to allow access to where ever you put it.
Posted: Fri Mar 19, 2010 3:13 am
by SquALeD
Thanks for the replies guys, much appreciated..
antar, is there any chance you could elaborate a little for me? I've bee accessing apache thru webmin and played with the virtual host settings. At present zomeminder is on the default host. How would i set it up so i could have my website running on
www.myip.com and zm on
www.myip/zm?
diven, could you elaborate a little on what you posted too please ?
I understand I can have as many virtual hosts as I want within reason? Is this right? Just not too sure how to set things up.
Sorry guys I'm a zomeminder/Ubuntu newb
Sq
Posted: Sat Mar 20, 2010 4:12 pm
by diven
You should have a directory something like /var/www/htdocs which is your web server root. Add a directory named zm and put all the zm files in there.
Edit /etc/zm.conf to read:
# Path to ZoneMinder web files
ZM_PATH_WEB=/var/www/htdocs/zm
I don't use Ubuntu so I can't comment on the file structure or the default apache config but it should be similar.
A virtual host is for adding an additional hostname to your web server.
