How to add a remote monitor (Axis IP camera)
myusernameisunique
Post by myusernameisunique »
I'm having trouble creating a remote monitor for an Axis 212 PTZ network camera. It doesn't work - no image (not even a black window) when I try to open the live feed from ZM console. I configured it according to http://www.zoneminder.com/wiki/index.php/Axis, no success. Tried selecting different presets for Axis, same thing. The camera is set to 640x480 motion JPEG.
Any suggestions will be appreciated.
Thank you!
kingofkya
Post by kingofkya »
Check the logs my guess is you didn't read the part about shared memory
myusernameisunique
kingofkya wrote:Check the logs my guess is you didn't read the part about shared memory
For every attempt to open the monitor feed, zmdc.log says:
03/22/2010 16:59:07.071464 zmdc[2757].INF [Starting pending process, zmc -m 3]
03/22/2010 16:59:07.087446 zmdc[2757].INF ['zmc -m 3' starting at 10/03/22 16:59:07, pid = 7187]
03/22/2010 16:59:07.103025 zmdc[2757].ERR ['zmc -m 3' exited abnormally, exit status 255]
I did configure kernel.shmmin and kernel.shmmax. Is that what you're referring to, and what values do you recommend for a computer with 1GB of RAM?
On ZM console, Remote monitor Mode is shown in orange color and Source in red, whereas a working local monitor is all green. Does it have any significance?
Thanks!
kingofkya
Post by kingofkya »
ok does the url you have in the camera output the resolution you have set in in zm
In my axis cams i have the RemoteHostPath like this
/axis-cgi/mjpg/video.cgi?resolution=800x600
and Capture Width and Height are
800 600
they must match
myusernameisunique
kingofkya wrote:ok does the url you have in the camera output the resolution you have set in in zm
they must match
Yes, they are the same. I copy-paste the URL from ZM settings to Firefox and it works no problem there - I see an mJPEG video stream from the camera.
whatboy
Post by whatboy »
It ain't SHMMIN... it is...
kernel.shmall
kernel.shmmax
myusernameisunique
kernel.shmall
kernel.shmmax
My bad, thanks for the correction! The mistake is just in the post, not in the actual config file.
kingofkya
Post by kingofkya »
I cant think of anything off hand that might be the problem. You an send me a link to your ZM server and I can take a look for you.
myusernameisunique
kingofkya wrote:I cant think of anything off hand that might be the problem. You an send me a link to your ZM server and I can take a look for you.
Thanks so much kingofkya again for your time to fix my problem. You're a king of ZM for sure! :-) I got the camera live feed working after reboot.
So, it was my mistake in shared mem configuration: in /etc/sysctl.conf, I entered kernel.shmall and kernel.shmmax parameters in one line instead of two different lines in the file.
that is, instead of:
kernel.shmall = 134217728
kernel.shmmax = 134217728
it was:
So simple, I'm feeling ashamed... :-) But from my experience, many problems are caused by most simple mistakes....
