I'm going to the problem:
I bought a IpCamera Mpeg4 (like in the subject of the post), it's been connected trough a router on a Lan.
Ok, if I enter on the Webcam Control panel i can see it right, if i specify (as a remote source) on Zoneminder it remains black with a Status: Idle 0.0 FPS
I've tried every type of configuration, remote with every type of Ip adress (specifying subpath too), locale specifying everything possible, and so on...
I've searched on the forum and on the net, but anyone speaks so well of configuration of this ipCamera
Can Anyone help me to understand the right configuration (if it's possible) and at least the right path (on the camera) where I can find a streaming video (in jpeg, asf or anything else) ?
Thank you so much for the time and for (hoped) answer :
And Sorry for my bad english...
P.s.: The Zoneminder version is v1.23.3 mounted as virtual machines on a Ubuntu Server (intrepid)
Thank you againd
EDIT: Seeing on zmwatch.log, i can see this error:
Can't get shared memory id '7a6d0002', 2: No such file or directory]
Now I search on forum if there is a solution, but if someone would to answer in the while, is the welcome
