index.php is not run on startup
buddybamboo
Post by buddybamboo »
I am new to Zoneminder, and also the use of Apache2, and the associated files. I am trying to get 1.24.2 up on a netbook atom processor. The problem appears that php5 mods-enabled files [php5.load php5.conf] are not there. Zoneminder starts successfully, and apache5 starts clean. I have tried several times to load php5 as described in the forums. Everything seems to go smoothly, but after restarting apache2, those 2 files are still not there. When I try to start the webpage, the message asks what to open index.php with.
I have zoneminder working on my desktop.
Would appreciate any suggestions.
Ubuntu 9.10 remix
whatboy
Post by whatboy »
From http://www.zoneminder.com/wiki/index.ph ... dow_etc.3F
If you are using Apache, which is the most common one, then in your httpd.conf file there should be a line like
buddybamboo
Thanks for the information. I found even the desktop that works has nothing in the httpd.conf file.
What I did before was to look at the one that worked files in mods-available, and mods-enabled and put what I found in the netbook. This didn't work. Then I discovered that the reboot whipped out the mods-enabled files were gone. I then discovered they were supposed to be linked to mods-available. Linking them fixed the problem! php5.conf contained:
<IfModule>
AddType application/x-httpd-php .php .phtml .php3
AddType application/x-httpd-php-source .phps
</IfModule>
php5.load contained:
LoadModule php5_module /usr/lib/apache2/modules/libphp5.so
Why these were not loaded in the process of installing Zoneminder I don't know.\
The problems forced me to learn alot.
Mahalo
George
