I'm about to setup zoneminder with a kodicom 8 channels (cloned but uses the exact same chipsets) and 3 sony ccd 1/3" but zmc tells me "Signal not detected (X)" for all 3 cameras.
Temporarily using a RCA cable with BNC plugs, then video and power will run over a CAT6 using baluns.
I've plugged the camera into VID1 on the back of the card and selected video0 as source, did also tried using video1,2 .... 7 but all I get is a black screen and "Signal not detected (X)".
Any help would be appreciated before all my wife clothes get stolen from the clothesline ... seems funny but we also had 2 break in attempt in just few days and I'm really worried about my family's safety. Door/windows sensor have just been installed (will try to use X10 later on) but I would love the cameras working as well.
Thanks for your reply,
modprobe and shared memory followed by a reboot was done and I will try other video programs to see how it goes.
Dealing with an unexpected issue now ... a .file or .folder inside my home is around 750GiB and the system its very unstable now ... init 1 to get things done ... bbs.
Right after I've used cheese webcam booth, zoneminder was able to pick up frames, jpeg works too.
Fedora 12 amd 64, 2gb ddr3, 4x250gb w/ software raid5.
3 x 520tvl 1/3" ±25fps monitors and the total load was ±0.7 including essential server services, media streaming with two working clients at the time and a gnome session.
Great work guys! Zoneminder was increasing the load by probably 0.3 only.
