Hello. Let me first say I don't even have a Linux box built. I'm in the evaluation of what to do phase, and I'm trying to research costs etc.
My old survellience system has 4 cameras, but the motion detection is horrible as any cloud shadow triggers it. I am discarding the DVR and keeping the cameras.
A friend has recommended ZonMinder which brought me to this forum.
Looking at the documentation, it is possible to trigger a monitor (I assume it means to record the camera?) via an X10 device.
Can someone tell me
A) What device I use on the PC side to interface X10 to PC?
B) Which X10 motion detection device I should use to trigger monitor?
I want to build my PC with a low power mini ITX form factor, so preferably a USB device would be used.
Thanks.
Jeff
Newbie trigger question
A good starter card from ebay
also I recommend using the ZMarch cd as it's setup and ready to go.
http://cgi.ebay.com/New-2-pcs-8-Channel ... 2300392083
I was actually considering this, to stick with USB. There are some Linux drivers for it as well.
http://www.dealextreme.com/details.dx/sku.11127
But my concern at this point is how to trigger the recording of a camera based on an actual motion/PIR sensor and not the change on the camera.
Thanks.
Thanks.
Hi. I haven't gotten any answers to the original question regarding which recommended hardware can I use to capture an X10 motion detector activity to have the monitor recorded.
Does anyone have any experience with this hardware to do that kind of activity?
http://www.smarthome.com/4832/X10-RF-Re ... ter/p.aspx
Thanks.
Jeff
Thanks.
Jeff
It did seem too good to be true. I'll stick with the PCI route. Although that would limit my cameras unless there is a slicker solution out there.kingofkya wrote:Most if not all usb capture devices have issues. More than 1 might not work too easy to remove not reliable.
Very few will help you with that card if it works at all.
also there is bluecherry but there a little more expansive than ebay but they have good suport.
I have reposted this in the hardware section. Please do not post replies in this thread.
It can be found here.
http://www.zoneminder.com/forums/viewto ... 1023#61023
Regards,
Jeff
Regards,
Jeff
Ordered a pair, thanks for the tip.jeffjohnvol wrote:I was actually considering this, to stick with USB. There are some Linux drivers for it as well.
Thanks.
