like one line is being droped then added again witch causes a alarm event every couple minuits
this fills the hd with non-event events
i cant tune it out in zones w/o killing motion detection alltogether
i used live disk v1.23.3 to install
Digital Power Supply Synchronization Method
The Full Digital Method Line Lock is realized in this camera, which adjusts
the vertical camera synchronization directly to improve controllability and
reliability of the camera.
Set to OFF, the camera activates the internal synchronization mode and set to ON, the power
synchronization mode. If you connect multi cameras to the sequential switcher to enter the
automatic conversion mode, the screen will bounce every screen while the camera stays in
INT(internal synchronization). Such bouncing phenomena may be cleared and screen conversion
becomes smooth by setting the L/L switch to ON and using the INT/DEC switch to control the
vertical synchronous phase.
â
