Inconsistent fps in generated videos if buffers changed
Posted: Wed Mar 31, 2010 9:25 pm
ZM 1.24.2 on Ubuntu 9.10
Generating an mpg video clip for every alarm - local monitor - BT878 video capture card - 320x240.
1. If I increase Pre- and Post- Event Image Count settings in a monitor settings / Buffers, the resulting video clip's rate gets distorted: the actual FPS initially, then I suddenly get a couple seconds of fast motion, like 2x rate, then normal fps, then sometimes accelerated motion again, then normal...
I installed ZM on a different computer previously (same video capture card) and I didn't have this issue. Basically, followed exactly the same steps for OS / ZM installation and used same params throughout...
2. How can I set up ZM for the best video quality of generated alarm videos possible (lowest compression rate)? The mpg files I get with the default settings come out pretty low res - little squares all over during motion... Tried different output formats, same thing visually. I know it means larger size but that's okay.
I'd greatly appreciate any suggestions.
