Page 1 of 1
Authentication question
Posted: Thu Apr 01, 2010 5:33 pm
by Sergio
I've been using Zoneminder for about 6 months now and it is stable, easy to use & reliable! Yippee! Thanks guys. Is it possible to make it so that all external connections to ZM must be authenticated, but internal connections do not? IE
Http://192.168.20.100 would not require a login to see the cameras.
Http://www.MyURL.com would require a login to see the cameras.
Posted: Fri Apr 02, 2010 5:17 am
by kingofkya
you might be able to achieve this with a htacces that auto logins for local connections.
