Page 1 of 1
Modect stops detecting
Posted: Sat Apr 03, 2010 4:21 pm
by clinicalobeast
I'm running 1.24.2 and set up with a webcam to monitor an outside view. These are always more tricky than inside views. Anyway, it took me a while to adjust the sensitivity etc.
So i had it detecting as you'd expect. Then i leave it running and 24 hours later, it's not detecting anymore, even with blatent content (jumping up and down). So i adjust the sensitivity a bit and still nothing.
But when i change the setting from Modect to something else and then back, it's all working again, even with the original sensitivity settings !
anyone else have this?
i'm going to leave it running and see if this is a one off or not....
Posted: Sun Apr 04, 2010 10:07 am
by jfkastner
check with 'top' if zma still runs - maybe it stalls and does not get restarted automatically (zma=analyze process / zmc=capture process)
also check the option/setting where it says 'restart capture daemon after ... seconds'
Posted: Sun Apr 04, 2010 2:04 pm
by clinicalobeast
Thanks, it looks like i have that option checked already.
Since yesterday, it's been ok. i'm going to keep an eye on it over the next few days.
