15 Avercont 1310 IP camera and ZM (extremlly low fps)
Posted: Thu Apr 08, 2010 10:03 pm
Hy!
I WANT TO INCREASE FRAME RATE
I try tu use ZM with more tath one Arecont Vision IP camera.
Resolution is 1,3 Mpix, 1280*1024 data rate about 15-20 Mbps
For 1 camera the frame rate is up to 20 fps
For two cameras bandwich goes irregular and frame rate up to 5.
For three cams frame rate about 2.
When I was try with internet IP cameras I was get from 5-40 fps depending of the camera and server eats more tath 20 mbps of internet. Now I cant get a normal frame rate in ZM when the propietary software of arecont has a minimum of 10 fps per camera in a slow computer.
ZM server is core2quad 2,8 or 2,6 9400, asus p5ql pro with gigabit lan (drivert installed from elrepaso), lan for remote wieving tp-link 10/100, 2 gb ram, 1 tb hdd.
During the problem bwm-ng show from 5-20 mbps network traffic and tom or htop less tath 50% cpu usage
