apache crash - zm 1.24.2 - gentoo - IP Bewan icam 200G
christophe_y2k
Post by christophe_y2k »
On recent install of ZM V1.24.2 on my Gentoo server ...
With one ip cam bewan icam 200g (good product for -120€)
That work very fine for a moment
after some time a bug zm not responding
no error log from zm but
Apache error LOG two last line :
[error] [client 80.14.xx.xx] array (\n 0 => \n array (\n 'file' => '/var/www/localhost/htdocs/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /var/run/zm/zms-786616s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/localhost/htdocs/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/localhost/htdocs/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://xxxxx.dyndns.org/zoneminder/inde ... c=1&page=1
[Fri Apr 09 14:55:40 2010] [error] [client 80.14.xx.xx] CGI process 21867 didn't exit, sending SIGKILL, referer: http://xxxx.dyndns.org/zoneminder/index ... 1=1&page=1
another crash of apache ...
Fri Apr 09 22:27:09 2010] [error] [client 79.87.xx.xx] socket_sendto( /var/run/zm/zms-743574s.sock ) failed: No such file or directory, referer: http://xxxx.dyndns.org/zoneminder/index ... atch&mid=1
[Fri Apr 09 22:27:09 2010] [error] [client 79.87.xx.xx] array (\n 0 => \n array (\n 'file' => '/var/www/localhost/htdocs/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /var/run/zm/zms-743574s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/localhost/htdocs/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/localhost/htdocs/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://xxxx.dyndns.org/zoneminder/index ... atch&mid=1
with ZM error in event list : date 1970 and negative duration...
112 Event-112 1970-01-01 01:00:00 -17654732.14 45/5 9/11 X
111 Event-111 2010-04-09 19:48:30 34.89 109/37 51/83 X
the tips is to stop & restart apache
Any idea ?
