Warning, overriding installed ./zm.conf file with local copy
Posted: Sat Apr 10, 2010 12:10 pm
I seem to be hitting an error for reasons I don't fully understand. There are a couple of posts here which mention the error, but they have not helped me to clear it up.
I have set up ZM on Debian a few times, and have a working 1.23.3 - so I'm not totally new at this. My issues come from compiling zm from source on Slackware 13.
These are the steps I've taken, and the order.
Next log into mysql as root and create the database thus: (MySQL prompt not shown for clarity of commands)
Edit the /usr/local/etc/zm.conf to suit the different db credentials:
Set it so it can be world read (bad, but just in case):
To allow it to run at boot I copy the 'zm' script and +x it with:
But if I attempt to start it and it bails with:
NB 'zmpkg.pl start' does the same but lacks the '[FAILED]' on the end - same result, does not start. I note that these are the wrong (and default) credentials I've just replaced in /usr/local/etc/zm.conf. Checking the file it's not been overwritten at all. It's like it's not reading my zm.conf or can't read it.
To troubleshoot this I add the default MySQL user thus:
It does then start, but complains:
Browsing to http://host/zm fails with the warning:
Looking over the docs, the only thing I could have missed is the ./configure options:
ZM_DB_PASS
ZM_DB_USER
But my understanding is these merely produce the template for zm.conf anyway and it should work with 'zmuser/zmpass'???
I've looked at this long and hard, I've got to be missing something really obvious here???? [/code]
./configure --with-webdir=/srv/httpd/htdocs/zm --with-cgidir=/srv/httpd/cgi-bin
[no errors]
make
make install
create database zm
grant select,insert,update,delete on zm.* to 'z0neUSER'@localhost identified by 'z0nem1nder';
use zm;
source db/zm_create.sql
quit
# ZoneMinder database user
ZM_DB_USER=z0neUSER
# ZoneMinder database password
ZM_DB_PASS=z0nem1nder
chmod 644 /usr/local/etc/zm.conf
cp /usr/local/src/ZoneMinder-1.24.2/scripts/zm /etc/rc.d/rc.zm
chmod +x /etc/rc.d/rc.zm
/etc/rc.d/rc.zm start
Starting ZoneMinder: Warning, overriding installed ./zm.conf file with local copy
DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/lib/perl5/site_perl/5.10.0/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/lib/perl5/site_perl/5.10.0/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.10.0/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/lib/perl5/site_perl/5.10.0/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/lib/perl5/site_perl/5.10.0/ZoneMinder.pm line 33.
Compilation failed in require at /usr/local/bin/zmpkg.pl line 46.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 46.
[FAILED]
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
flush privileges;
[ OK ]
touch: cannot touch `/var/lock/subsys/zm': No such file or directory
I don't appear to have any issues with the MySQL users as I can log in using zmuser with password zmpass and view all the tables etc:Could not connect to database: Access denied for user 'zmuser'@'localhost' (using password: YES)
mysql -u zmuser -p
Enter password:
mysql> use zm
Database changed
mysql> show tables;
| Tables_in_zm |
| Config |
| ControlPresets |
| Controls |
| Devices |
| Events |
| Filters |
| Frames |
| Groups |
| MonitorPresets |
| Monitors |
| States |
| Stats |
| TriggersX10 |
| Users |
| ZonePresets |
| Zones |
ZM_DB_PASS
ZM_DB_USER
