card issues - zmc errors out
Posted: Sat Apr 10, 2010 6:02 pm
I know this isn't the best card I could buy but I feel it should work. I'm having a problem with the feeds getting the following error:
This happens quite often and I've tried changing the card type with insmod too. The chip uses saa7130/34 v4l driver (SAA7130HL is on the chips).
I've tried searching the web and this site but haven't seen any real info about this issue or a fix for it. If you need more info let me know.
By the way great software, I'm running at home and love it I just need this card to stop doing this as it drops the modect for up to 2 minutes while it resets.
Apr 9 14:56:57 movies2 zma_m1[32252]: INF [Door: 7000 - Processing at 9.90 fps]
Apr 9 14:57:27 movies2 zmc_dvideo0[32403]: INF [Door: 4000 - Capturing at 10.00 fps]
Apr 9 14:57:44 movies2 zmc_dvideo0[32403]: ERR [Sync failure for frame 1 buffer 2(1): Input/output error]
Apr 9 14:57:44 movies2 zmc_dvideo0[32403]: ERR [Failed to post-capture monitor 0]
Apr 9 14:57:44 movies2 zmdc[32225]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
Apr 9 14:57:44 movies2 zmdc[32225]: INF [Starting pending process, zmc -d /dev/video0]
Apr 9 14:57:44 movies2 zmdc[32225]: INF ['zmc -d /dev/video0' starting at 10/04/09 14:57:44, pid = 32517]
Apr 9 14:57:44 movies2 zmdc[32517]: INF ['zmc -d /dev/video0' started at 10/04/09 14:57:44]
Apr 9 14:57:44 movies2 zmc_dvideo0[32517]: INF [Debug Level = 0, Debug Log = <none>]
Apr 9 14:57:44 movies2 zmc_dvideo0[32517]: INF [Starting Capture]
Apr 9 14:58:38 movies2 zma_m1[32252]: INF [Door: 8000 - Processing at 9.90 fps]
