[SOLVED]Can you tell me how to fix the ZM Debian package?
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
st2000
Post by st2000 »
Hi...
I get these errors installing ZM onto a debian box:
Setting up zoneminder (1.24.2-2.1) ...
insserv: warning: current stop runlevel(s) (0 1 6) of script `ntp' overwrites defaults (empty).
insserv: warning: current stop runlevel(s) (1) of script `nvidia-kernel' overwrites defaults (empty).
insserv: warning: current start runlevel(s) (2 3 4 5) of script `vlc' overwrites defaults (empty).
insserv: warning: current stop runlevel(s) (0 1 6) of script `vlc' overwrites defaults (empty).
insserv: warning: current stop runlevel(s) (0 1 6) of script `nvidia-glx' overwrites defaults (empty).
Starting ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) failed: Unknown database 'zm' at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
failure
invoke-rc.d: initscript zoneminder, action "start" failed.
dpkg: error processing zoneminder (--configure):
 subprocess installed post-installation script returned error exit status 255
Errors were encountered while processing:
 zoneminder
Does anyone know how to fix creating a ZM data base?
What about the PERL script errors?
I'm a bit new at this, but if I can fix this, I'll look into submitting it so other Debian users can use the Debian ZoneMnider package.
-thanks
st2000
Re: Can you tell me how to fix the ZM Debian package?
Post by st2000 »
st2000 wrote:Hi...
>>>snip<<<
-thanks
Wow, I don't know if everyone is stumped, nobody is here or Debian is not the way to go when setting up a zoneminder box...
But, with the help of the packager and others else where I've got ZM installed on the box which gave the above problems.
In short, there were *zoneminder* files left lying around which, I assume, gave the Debian package installer problems. Most were broken links with the following name: "/etc/rc?.d/*zoneminder.conf" Note the use of UNIX wild card characters as this represents about half a dozen different files. Other files I removed which might have been the problem:
/etc/apache2/conf.d/zoneminder.conf
/var/lib/update-rc.d/zoneminder
/var/cache/apt/archives/zoneminder_1.24.2-2.1_i386.deb
If you have similar problems and the above is not enough detail post as I'll try to monitor this thread.
-thanks
