[RESOLVED] No image in my ZM ...
Posted: Thu Apr 15, 2010 11:03 am
Hello Evrybody,
I try to install my firt ZoneMinder server and i have some troubles.
First, here is a summury of my configuration :
This is my /etc/modprobe.d/bttv.conf :
The command "ls - /dev/ | grep video" return :
I tested my camera with "Cheese" software, it works on /dev/video2 device !
The command "zmu -d /dev/video2 -q -v" return :
Then I created this monitor (i use preset "BTTV Video, PAL, 640x480) :
But no image...
My "/tmp/zmdc.log" contain :
I don't understand the reason of this error... Evrybody have an idea ?
Thanks a lot.
Regards.
- Intel Dual Core 2,8Ghz
- 8 Channel 240 FPS Zoneminder Compatible Capture Card using the Connexant 878A Chip (available on this website : http://www.camsecure.co.uk/Zoneminder.html).
- Analogic Samsung SCC 5366 camera
- Xubuntu 9.10 32bits
- Zoneminder from apt-get (Version: 1.24.1-1ubuntu2)
options bttv gbuffers=32 card=102,102,102,102,102,102,102,102 tuner=0 radio=0 coring=1 full_luma_range=1 chroma_agc=1 pll=1 combfilter=1 autoload=0 triton1=0
crw-rw----+ 1 root video 81, 1 2010-04-15 07:40 vbi0
crw-rw----+ 1 root video 81, 3 2010-04-15 07:40 vbi1
crw-rw----+ 1 root video 81, 5 2010-04-15 07:41 vbi2
crw-rw----+ 1 root video 81, 7 2010-04-15 07:41 vbi3
crw-rw----+ 1 root video 81, 9 2010-04-15 07:42 vbi4
crw-rw----+ 1 root video 81, 11 2010-04-15 07:42 vbi5
crw-rw----+ 1 root video 81, 13 2010-04-15 07:43 vbi6
crw-rw----+ 1 root video 81, 15 2010-04-15 07:43 vbi7
crw-rw----+ 1 root video 81, 0 2010-04-15 08:15 video0
crw-rw----+ 1 root video 81, 2 2010-04-15 08:15 video1
crw-rw----+ 1 root video 81, 4 2010-04-15 08:15 video2
crw-rw----+ 1 root video 81, 6 2010-04-15 08:15 video3
crw-rw----+ 1 root video 81, 8 2010-04-15 08:15 video4
crw-rw----+ 1 root video 81, 10 2010-04-15 08:15 video5
crw-rw----+ 1 root video 81, 12 2010-04-15 08:15 video6
crw-rw----+ 1 root video 81, 14 2010-04-15 08:15 video7
Video Capabilities
Name: BT878 video (IVC-200)
Type: 45
Can capture
Does teletext
Overlay onto frame buffer
Can clip
Video Channels: 1
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 8 - YUYV
Colour Depth: 16
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
But no image...
15/04/2010 12:12:21.286989 zmdc[3316].INF [Server starting at 10/04/15 12:12:21]
15/04/2010 12:12:24.495695 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:12:24, pid = 3338]
15/04/2010 12:12:24.540257 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:12:24.540623 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:12:24.541888 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:12:24, pid = 3340]
15/04/2010 12:12:24.615651 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:12:24.739619 zmdc[3316].INF ['zmfilter.pl' starting at 10/04/15 12:12:24, pid = 3341]
15/04/2010 12:12:24.953763 zmdc[3316].INF ['zmaudit.pl -c' starting at 10/04/15 12:12:24, pid = 3343]
15/04/2010 12:12:25.184260 zmdc[3316].INF ['zmwatch.pl' starting at 10/04/15 12:12:25, pid = 3345]
15/04/2010 12:12:29.089626 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:12:29.091066 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:12:29, pid = 3348]
15/04/2010 12:12:29.121397 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:12:39.034250 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:12:39.035644 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:12:39, pid = 3384]
15/04/2010 12:12:39.066311 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:12:59.041480 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:12:59.042862 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:12:59, pid = 3395]
15/04/2010 12:12:59.073204 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:13:39.022669 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:13:39.024092 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:13:39, pid = 3405]
15/04/2010 12:13:39.054405 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:14:59.051446 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:14:59.052833 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:14:59, pid = 3414]
15/04/2010 12:14:59.083596 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:17:39.077895 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:17:39.079312 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:17:39, pid = 3418]
15/04/2010 12:17:39.109915 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:22:59.034733 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:22:59.036158 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:22:59, pid = 3442]
15/04/2010 12:22:59.066698 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
15/04/2010 12:32:59.183364 zmdc[3316].INF [Starting pending process, zmc -d /dev/video2]
15/04/2010 12:32:59.188735 zmdc[3316].INF ['zmc -d /dev/video2' starting at 10/04/15 12:32:59, pid = 3614]
15/04/2010 12:32:59.243202 zmdc[3316].INF ['zmc -d /dev/video2' crashed, signal 6]
Thanks a lot.
Regards.
