[1.23.3] DVR buttons don't work with Google Chrome
Diviner
Post by Diviner »
Hi!
Only on chrome zm dvr buttons don't work and i get the following error on apache error log: "socket_sendto() failed: No such file or directory". On the chrome debugger i get the following js error: "Refused to set unsafe header "Connection"".
Any suggestion?
masanee
Post by masanee »
Why does Google Chrome not work properly with the 150% larger setting?
Using Windows 7, I increased the size of everything 150% since the screen is so large it fits better. Using Google Chrome, however, the text in the address bar is larger that the bar itself, and the bottom of the text is getting cut off...
______________________
affiliateelite ~ affiliateelite.com ~ adgooroo ~ adgooroo.com
