Increase Frames/Sec - AirLive OD-600HD
Posted: Sun Apr 18, 2010 3:35 pm
I am trying to increase the frames/sec for my Airlive OD-600HD. I have tried just about everything I can think of. The FPS from the web based viewing direct to the camera gets me at least 15 FPS and things look great. However, in ZM I can never get better than 4 FPS. I have played with the ffmpeg options to no avail.
Here are the settings for the camera via the internal web based access .
Video Type : H264
Resolution : 640x480
Frame Rate : 15
Bitrate : 2772
Here are some details about the web based access from the log file. I have tried to enter the "path" in ZM but it gets me no image at all.
May 10 08:55:32 AirCam OD-600HD user.debug rtsp-svr: client request: 'TEARDOWN' 'rtsp://192.168.123.100:554/h264/media.amp?resolution=vga/' 'RTSP/1.0'
May 10 08:55:32 AirCam OD-600HD user.debug rtsp-svr: 1 found stream path: '/h264/media.amp?resolution=vga', path: '/h264/media.amp?resolution=vga/'
Here are the setting for ZM to the cam :
Remote Protocol : HTTP
Remote Method : Simple
Remote Host Name : admin:airlive:192.168.123.100
Remote Host Port : 80
Remote Host Path : /mjpg/video.mjpg?resolution=vga
Remote Image Colours : 24 bit colour
Capture Width (pixels) : 640
Capture Height (pixels) : 480
Preserve Aspect Ratio : Not checked
Orientation : Normal
Any help/suggestion are appreciated. Thanks.
Video Type : H264
Frame Rate : 15
Bitrate : 2772
