Using mpeg option over jpeg for STREAM_METHOD
alamolou
Post by alamolou »
I would like to utilize the mpeg option for my ZoneMinder system. I believe I have everything necessary for ffmpeg set up on the server, however whenever I try to pull up a camera rather than show the video stream it is blank. What would I have to have set up for MPEG_LIVE_FORMAT and FFMPEG_FORMATS?
sezamnet
Re: Using mpeg option over jpeg for STREAM_METHOD
Post by sezamnet »
What do the logs show? When you compile ZoneMinder you used the "- with-ffmpeg =?
What do you see after the command "ffmpeg"?
While compiling ffmpeg and ZoneMinder, did not receive an error?
ZM_FFMPEG_FORMATS - here you give the file formats generated from the event. "* Mpg mpeg wmv avi mov 3gp asf swf **"
ZM_MPEG_LIVE_FORMAT - stream format. I recommend swf or asf
ZM_STREAM_METHOD - mpeg
ZM_OPT_CAMBOZOLA - mark
