2 Kodicom 8800 poor quality images
Posted: Tue Apr 20, 2010 2:16 pm
hello list, I have two 8800 kodicom capturadoas 240 fps each. These captors installed on windows xp, work very well, but ZM is very poor quality.
I have tried several configurations but the quality does not improve
Here I spend my settings to think about
V4L_MULTI_BUFFER disable
CAPTURES_PER_FRAME = 0
STREAM_METHOD MPEG
MPEG_LIVE_FORMAT swf
Capture Method V4l2
PALN
320*240
YUV422P
MAX FPS : 15
ALARM FPS : 15
Bufers
80
25
10
60
1000
the problem is that when I load a camera to her, begins to visualizarce normal, and as the seconds pass is losing quality and look like the image below
if anyone can help me improve the quality of the images I would appreciate
STREAM_METHOD MPEG
Capture Method V4l2
PALN
320*240
YUV422P
MAX FPS : 15
ALARM FPS : 15
Bufers
80
25
10
60
1000
