I have 4 ACTI cameras setup in MJPEG @ 640x480 15fps (they are capable of 1024x1280) and 1 Airlive 325 in MJPEG also.
Two of my ACTI cameras are in a constant motion area (during the day) and are set on Modect. These two are constantly producing errors in the logs and have gaps between events. The logs look like this:
Apr 20 11:19:25 ubuntuzm32 zmc_m12[902]: INF [CNC-W: 8000 - Capturing at 7.52 fps]
Apr 20 11:19:26 ubuntuzm32 zmc_m13[906]: INF [CNC-East: 16000 - Capturing at 14.93 fps]
Apr 20 11:19:32 ubuntuzm32 zma_m12[904]: INF [CNC-W: 7095 - Gone back into alarm state]
Apr 20 11:19:32 ubuntuzm32 zma_m12[904]: INF [CNC-W: 7096 - Gone into alert state]
Apr 20 11:19:35 ubuntuzm32 zma_m12[904]: INF [CNC-W: 7100 - Gone back into alarm state]
Apr 20 11:19:37 ubuntuzm32 zmc_m13[906]: WAR [Buffer overrun at index 45, image 16170, slow down capture, speed up analysis or increase ring buffer size]
Apr 20 11:19:38 ubuntuzm32 zma_m13[908]: WAR [Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size]
Apr 20 11:19:38 ubuntuzm32 zmc_m13[906]: WAR [Buffer overrun at index 56, image 16181, slow down capture, speed up analysis or increase ring buffer size]
Apr 20 11:19:39 ubuntuzm32 zma_m12[904]: INF [CNC-W: 7109 - Gone into alert state]
Image buffer Size =75
Warmup = 12
Pre Event image Count =45
Post Event image count = 60
I have tried several variations of the ring buffer, higher, lower and still get the errors.
My other cameras are fine and respond to alarms and record correctly. Just these two give me problems. Is Zoneminder not capable of doing modect when there is constant motion? Would I be better off setting these as "Record" until evening then going back to modect? Thank you in advance for all for the help.
