Page 1 of 1
outdoor long-distance camera, advice?
Posted: Mon May 03, 2010 7:09 pm
by mighty
Hi all-
Trying to decide if I should take this project on given a small budget and big requirements.
I need an outdoor daylight camera at my home that will monitor a 100-foot-wide gate area that is 200 to 380 feet from the camera. It's not necessary to see faces or license plates, but vehicles and people should be roughly recognizable.
The camera will be 330 feet from the PC, through some tall trees. I would prefer a battery-powered IP camera in order to avoid running wires -there is no power out there- but cost and battery life will decide.
What are the options and rough costs with this setup? I have seen some very expensive cameras but I hope there are alternatives. I'm willing to sacrifice some reliability, and I'm OK with building my own enclosure, mount and power supply if necessary.
Thanks for your advice.
Posted: Wed May 05, 2010 2:55 am
by kingofkya
Well if you are running a wired ip cam get POE adapters. If you want to go 100% wireless use a wireless ip cam with a small solar pannle and 12v battery. Also don't forget diodes on the battery to prevent discharge as for the camera it really depends on what you want to spend.
Posted: Wed May 05, 2010 5:40 am
by Flasheart
http://www.axis.com/products/cam_207w/ is not an external camera, but the megapixel does give a much better image at the further distances.
Agree with king about PoE. Use a PoE injector such as http://www.ciao.co.uk/Buffalo_AirStatio ... r__5819772 at the house. Run cat5 out to the camera and have a splitter like http://www.dlink.com/products/?pid=368 to extract it to the camera.
House all in a waterproof enclosure.
I have used Solar and wireless before. Results were not great. You'll need to do the maths and use plenty of panels and a hefty battery as wifi uses much more than wired. It will also be much much less reliable than poe/wired. I don't recommend this route unless you are prepared to spend a lot of time fiddling with stuff and cursing the world when you need to check something and you discover it stopped working 2 days ago.
Posted: Wed May 05, 2010 7:46 am
by kingofkya
oh and from experance the cheap 50$ ups that on ewith built in splitter can run 2 axis cams and poe switch for 1 week +- a day
http://www.newegg.com/Product/Product.a ... 6842101344
Re: outdoor long-distance camera, advice?
Posted: Sun Apr 17, 2011 12:00 pm
by rmorrison100
Same here, I vote for PoE.
Posted: Thu Aug 18, 2011 9:20 am
by shinichy
Hello Mighty.
Well, as your name suggests, you are really mighty. I appreciate the courage and for being an optimist. Mighty, regarding your case, what I can advice to you is to go for PoE adapters. They really fit, pretty much amazing home CCTV that's completely securing you.
Posted: Fri Aug 19, 2011 7:58 am
by jack520
The post tell us more knowledge,we can use it in our life.Thank you for the
Posted: Tue Dec 06, 2011 5:29 am
by MarvinLamont
In my opinion, CCTV offers security cameras that encompass a vast variety of features that will take care of any security system need. Another feature of these security cameras is that they are weatherproof which gives them the ability to use indoors or outdoors.
Posted: Sat Aug 25, 2012 11:16 am
by GorgeousPaws
i totally agree to it. Good advice!
Posted: Sun Jun 16, 2013 7:24 am
by ctopcctv
mighty wrote:Hi all-
hi, mighty,
it is not a problem. you could solve it according to ours.
1. using a waterproof analog 700tvl camera, it is enough for your request, it it cheap, about $70/pc, no need IP camera.
2. using PVD video balun and network cable to transmit video and power for camera, you could supply power for camera in your house. there are one PVD video balun item recommended in cctvvideobalun, it could transmit up to 300m, enough for yours. it is only $5/pair.
