stop ZM from sending out ANY kind of email
JungleGeorge
Post by JungleGeorge »
We have this ZM installation running on a small LAN with only 2 computers:
1. Running only ZM (server)
2. A desktop
Very simple, nothing elaborate.
On the ZM system the "/var/log/mail.log" contains a ton of messages like:
May 5 20:08:42 ZM1 nullmailer[14286]: smtp: Failed: Connect failed
May 5 20:08:42 ZM1 nullmailer[815]: Sending failed: Connection failed
May 5 20:08:42 ZM1 nullmailer[815]: Delivery complete, 469 message(s) remain.
We don't want ZM to send out any email messages at all.
How do you stop ZM from send out all the email messages?
kingofkya
Post by kingofkya »
if you have a mail server installed its just sending messages about syslog stuff (its really harmless) you should just have to unistall or stop postfix or whatever your mta is.
JungleGeorge
It looks like "/usr/sbin/nullmailer-send" was sending out these messages and the following files contained those logs:
/var/log/syslog
/var/log/mail.info
/var/log/mail.log
/var/log/mail.err
/var/log/mail.warn
So I uninstalled the "nullmailer" package.
The "/var/log/mail.*" files are not a problem any more.
The "/var/log/syslog" file is also much less chatty.
Thanks kingofkya.
