How to install live CD to hard drive
Posted: Thu May 13, 2010 2:53 am
Can't figure out what is happening, but I get a blank screen after running the liveCD. I wish to install the LiveCD to the hard drive.
This is what happens.
1) I get to a screen which has the following options
Default: no swap, no copy-to-ram
larch copy-to-ran (also activates swap)
larch with swap
Memory tester
I select the first one 'Default no swap, no copy-to-ram'
2) It then starts to load
3) All the services start-up '[busy]' [done]' etc etc
4) When they have finished it then auto logs on the zm_user
5) It is at this point I have a blank screen and my monitor says it cannot display the video.
6) I can connect via web browsers and webcams work
Because I cannot access the system via shell I cannot do much.
It seems likely it is a simple setting to change the resolution as when I ctrl+alt+del the machine then starts the shutdown process and the display comes back into life, I can see all the various service being stopped.
The machine is more or less Ok, I just can't see any thing
[/list]
larch with swap
Memory tester
