Page 1 of 1
Weird stuff
Posted: Fri May 14, 2010 2:29 pm
by Tiggy
Hi guys,
I didn't search the forums coz I don't know how I should describe my problem to you.
Since shortly recorded events seems to show up with a minut record time (event every minut); before an eent lastest 10 minuts.
I didn't change any configuration and didn't directly see what setting could cause zoneminder the record for 1 minut and then start new event.
Do any of you guys have an idea what is wrong or what needs to be changed?
Thx
Posted: Fri May 14, 2010 5:20 pm
by KeithB
go to :
Source->Misc->Section length
Then make that value 10 times what it is now.
Posted: Fri May 14, 2010 6:36 pm
by Tiggy
I did try that ... nothing changed ... after looking more into it I saw that every event off 1 min lenght had 0 frames ...
My hdd was at 1% used space; so i suppose it must be the amount off files causing problems (I have over 140000 events for 3 cameras) ...
Still deleting them ... is there a way to delete all events @ once? Filter gives memory error :|
I ll keep you guys posted afterwards
Posted: Fri May 14, 2010 6:40 pm
by Tiggy
I Manually deleted all pictures from the event directory but even after several hours they amount on zoneminder main window only dropped 20 à 30 events ...
Even weirder if you ask me :|
Even removing cameras themselves gives me:
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 16 bytes) in /home/zm/public_html/includes/database.php on line 125
Posted: Sun May 16, 2010 7:35 pm
by DREMA
What function are you using? Record, modec, etc ??
Posted: Sun May 16, 2010 7:54 pm
by Tiggy
REcord; but doesn't matter ... I deleted all events within the mysql table myself and there I saw the frames table was broken.
I repaired the database and now everything is fine again.
Laterz all :)
