Ubuntue 10.04 update broke anolog cameras remote work
Posted: Fri May 14, 2010 7:46 pm
First off spare me the shared memory sugestion its set as is the modprobe line.
xawtv can see the card fine so its working.
debug log
ZMDC
IDEAS
debug log
05/14/10 12:43:17.122971 zmc_dvideo0[-1].INF-zm_debug.c/292 [New Debug Level = 5, New Debug Log = /tmp/zm_debug.log.04912]
05/14/10 12:43:17.123365 zmc_dvideo0[-1].DB1-zm_monitor.cpp/1712 [Got 1 monitors]
05/14/10 12:43:17.123428 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/286 [V4L2 support enabled, using V4L2 api]
05/14/10 12:43:17.126313 zmc_dvideo0[-1].DB1-zm_monitor.cpp/338 [monitor purpose=1]
05/14/10 12:43:17.126354 zmc_dvideo0[-1].DB1-zm_monitor.cpp/345 [mem.size=36865524]
05/14/10 12:43:17.147319 zmc_dvideo0[-1].DB1-zm_zone.cpp/50 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:1$
05/14/10 12:43:17.175243 zmc_dvideo0[-1].DB1-zm_monitor.cpp/458 [Monitor Monitor-1 has function 2]
05/14/10 12:43:17.175284 zmc_dvideo0[-1].DB1-zm_monitor.cpp/459 [Monitor Monitor-1 LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, $
05/14/10 12:43:17.175293 zmc_dvideo0[-1].DB1-zm_monitor.cpp/460 [Monitor Monitor-1 IBC = 40, WUC = 25, pEC = 10, PEC = 10, E$
05/14/10 12:43:17.175477 zmc_dvideo0[-1].DB1-zm_zone.cpp/889 [Got 1 zones for monitor Monitor-1]
05/14/10 12:43:17.175495 zmc_dvideo0[-1].DB5-zm_zone.cpp/918 [Parsing polygon 0,0 639,0 639,479 0,479]
05/14/10 12:43:17.175503 zmc_dvideo0[-1].DB3-zm_zone.cpp/758 [Parsing polygon string '0,0 639,0 639,479 0,479']
05/14/10 12:43:17.175512 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,0 from polygon string]
05/14/10 12:43:17.175520 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 639,0 from polygon string]
05/14/10 12:43:17.175527 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 639,479 from polygon string]
05/14/10 12:43:17.175535 zmc_dvideo0[-1].DB3-zm_zone.cpp/796 [Got coordinate 0,479 from polygon string]
05/14/10 12:43:17.175547 zmc_dvideo0[-1].DB3-zm_zone.cpp/816 [Successfully parsed polygon string]
05/14/10 12:43:17.175558 zmc_dvideo0[-1].DB1-zm_zone.cpp/50 [Initialised zone 1/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:2$
05/14/10 12:43:17.199172 zmc_dvideo0[-1].DB1-zm_monitor.cpp/1814 [Loaded monitor 1(Monitor-1), 1 zones]
05/14/10 12:43:17.199216 zmc_dvideo0[-1].INF-zmc.cpp/188 [Starting Capture]
05/14/10 12:43:17.199473 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/349 [Opening video device /dev/video0]
05/14/10 12:43:17.199536 zmc_dvideo0[-1].DB2-zm_local_camera.cpp/355 [V4L2 support enabled, using V4L2 api]
05/14/10 12:43:17.199546 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/360 [Checking video device capabilities]
05/14/10 12:43:17.199562 zmc_dvideo0[-1].DB3-zm_local_camera.cpp/370 [Setting up video format]
05/14/10 12:43:17.199590 zmc_dvideo0[-1].FAT-zm_local_camera.cpp/386 [Failed to set video format: Invalid argument]
05/14/10 12:43:17.199721 zmc_dvideo0[-1].INF-zm_signal.cpp/64 [Got signal 6 (Aborted), exiting and forcing backtrace]
05/14/10 12:43:27.026334 zmdc[4861].INF [Starting pending process, zmc -d /dev/video0]
05/14/10 12:43:27.027868 zmdc[4861].INF ['zmc -d /dev/video0' starting at 10/05/14 12:43:27, pid = 4913]
05/14/10 12:43:27.140016 zmdc[4861].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
05/14/10 12:43:47.003746 zmdc[4861].INF [Starting pending process, zmc -d /dev/video0]
05/14/10 12:43:47.005292 zmdc[4861].INF ['zmc -d /dev/video0' starting at 10/05/14 12:43:47, pid = 4918]
05/14/10 12:43:47.112007 zmdc[4861].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
05/14/10 12:44:27.041304 zmdc[4861].INF [Starting pending process, zmc -d /dev/video0]
05/14/10 12:44:27.042858 zmdc[4861].INF ['zmc -d /dev/video0' starting at 10/05/14 12:44:27, pid = 4923]
05/14/10 12:44:27.160083 zmdc[4861].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
