Only Blue Picture
Posted: Thu May 20, 2010 2:05 pm
first of all sorry for my english
I have the following capture card:
TV8802 from Abus. The Card has the conexant fusion 878a chip and 4 BNC Inputs and one S-Video Output.
I installed Debian lenny and Zoneminder 1.24.2 with the Howto from the ZoneMinder wiki.
My kernel is 2.6.26-2-amd64.
my /etc/modprobe.d/bttv has this content: option bttv card=77
In ZM I configured one monitor with the following settings:
Device /dev/video0
Capture Method v4l2
Channel 0
Format PAL
Palett RGB565
width 320
height 240
And i got only a blue Picture... But the FPS where shown under the Picture and they are changing.
The Cam (checked on the tv) is connected over BNC. The User manual says:
1/4" Sharp CCD
PAL 512(H)X582(V) NTSC 512(H)X492(V)
HorizontalResolution 420 TV Lines
zmdc.log
Device /dev/video0
Capture Method v4l2
Channel 0
Format PAL
Palett RGB565
width 320
height 240
1/4" Sharp CCD
zeta002:~# zmu -d /dev/video0 -q -v
Video Device: /dev/video0
General Capabilities
Driver: bttv
Card: BT878 video ( *** UNKNOWN/GENER
Bus: PCI:0000:03:01.0
Version: 0.9.17
Type: 0x5010015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Has tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 1063 x 608
Default: 924 x 576
Current: 924 x 576
Inputs: 4
Input 0
Type: Tuner
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
05/20/10 15:46:56.891517 zmdc[2790].INF [Server starting at 10/05/20 15:46:56]
05/20/10 15:46:59.972745 zmdc[2790].INF ['zmc -d /dev/video0' starting at 10/05/20 15:46:59, pid = 2812]
05/20/10 15:47:00.054570 zmdc[2790].INF ['zmfilter.pl' starting at 10/05/20 15:47:00, pid = 2814]
05/20/10 15:47:00.139491 zmdc[2790].INF ['zmaudit.pl -c' starting at 10/05/20 15:47:00, pid = 2816]
05/20/10 15:47:00.170219 zmdc[2790].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
05/20/10 15:47:00.170414 zmdc[2790].INF [Starting pending process, zmc -d /dev/video0]
05/20/10 15:47:00.172180 zmdc[2790].INF ['zmc -d /dev/video0' starting at 10/05/20 15:47:00, pid = 2819]
05/20/10 15:47:00.183852 zmdc[2790].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
05/20/10 15:47:00.263464 zmdc[2790].INF ['zmwatch.pl' starting at 10/05/20 15:47:00, pid = 2820]
05/20/10 15:47:00.360845 zmdc[2790].INF ['zmupdate.pl -c' starting at 10/05/20 15:47:00, pid = 2822]
05/20/10 15:47:05.024958 zmdc[2790].INF [Starting pending process, zmc -d /dev/video0]
05/20/10 15:47:05.025573 zmdc[2790].INF ['zmc -d /dev/video0' starting at 10/05/20 15:47:05, pid = 2829]
05/20/10 15:47:05.036862 zmdc[2790].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
05/20/10 15:47:15.044983 zmdc[2790].INF [Starting pending process, zmc -d /dev/video0]
05/20/10 15:47:15.045991 zmdc[2790].INF ['zmc -d /dev/video0' starting at 10/05/20 15:47:15, pid = 2837]
05/20/10 15:47:15.058134 zmdc[2790].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
05/20/10 15:47:23.659827 zmdc[2790].INF [Command 'zmc -d /dev/video0' removed from pending list at 10/05/20 15:47:23]
05/20/10 15:47:23.745583 zmdc[2790].INF ['zmc -d /dev/video0' starting at 10/05/20 15:47:23, pid = 2845]
05/20/10 15:47:23.834336 zmdc[2790].WAR [Can't find process with command of 'zma -m 1']
