Capture and write on disk 1 frame per second -- possible ?
marcio123
Post by marcio123 »
Is it possible to set ZM to capture and write 1 frame per second (jpg) from all my cameras on my harddisk ?
How can I do it ?
Marcin Stępień
Marcin Stępień - Cieszyn
kingofkya
Post by kingofkya »
set fps to 1 in the camera settings
fps (Frames Per Second)
marcio123
Post by marcio123 »
I have max 6 FPS on every camera. That number makes it go without delay. If I set 1 FPS there is about 6-7 seconds delay (for screen to react)
Setting 1 FPS doesn't make it write 1 frame/s (JPG) on hard disk.
Marcin Stępień
KeithB
Post by KeithB »
If you are using IP cameras set the 1fps on the camera.
KeithB
Post by KeithB »
On some IP cameras you may need to put the fps in the Remote Host Path eg for Axis:
&fps=1
kingofkya
Post by kingofkya »
also the prebuffer needs to be set lower to achive more live images.
