Page 1 of 1
Error in zmfilter.log
Posted: Mon Mar 15, 2004 8:33 am
by wheelbarrow
I've configured e-mail to attach a viode. but i'm not getting it and instead get an error in the filter log file.
Can you help me work out what is causing this.
Rate is out of range, 0.25 >= rate <= 10
Sending notification email 'Alarm - Front-Door - 2004-03-15 08:02:59'
Regards
Paul
Re: Error in zmfilter.log
Posted: Mon Mar 15, 2004 10:34 am
by zoneminder
Hi Paul,
I think this may be a bug. The following patch might help, assuming it posts correctly.
----snip----
*** zmvideo.pl.z 15 Feb 2004 19:47:21 -0000 1.10
--- zmvideo.pl.z 15 Mar 2004 10:18:41 -0000
*** 77,83 ****
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
my $event_id;
! my $rate = 0.0;
my $scale = 1.0;
my $overwrite = 0;
--- 77,83 ----
my $event_id;
! my $rate = 1.0;
my $scale = 1.0;
my $overwrite = 0;
*** 117,125 ****
exit(-1);
! if ( $rate < 0.25 || $rate > 10 )
! print( STDERR "Rate is out of range, 0.25 >= rate <= 10\n" );
Usage();
--- 117,125 ----
exit(-1);
! if ( $rate < 0.25 || $rate > 100 )
! print( STDERR "Rate is out of range, 0.25 >= rate <= 100\n" );
Usage();
*** 232,244 ****
elsif ( ZM_OPT_MPEG eq "ffmpeg" )
my $frame_rate = sprintf( "%.2f", $event->{Frames}/$event->{FullLength} );
! if ( $rate != 0.0 )
$frame_rate *= $rate;
- else
- $frame_rate = 25.0;
my $width = $event->{MonitorWidth};
my $height = $event->{MonitorHeight};
--- 232,240 ----
! if ( $rate != 1.0 )
----snip----
Cheers,
Phil,
Posted: Mon Mar 15, 2004 11:09 am
by wheelbarrow
Hi Phil,
Ok i'll see if this fixes it.
Silly question, but i know i need to cut the text out of here and save it as a file. What should i do with it once i've saved it.
Regards
Paul
Posted: Mon Mar 15, 2004 11:28 am
by wheelbarrow
Ok Phil,
I've sorted that,
Ok so looking at the code it looks like it defaults to 25fps if the rate isn't sent over. Is this true. It;s just that the moves are runing fast.
I can send one over if you like.
Can i simply change the 25 to say 20.
Regards
Paul
Posted: Mon Mar 15, 2004 11:43 am
by zoneminder
That was what it _used_ to do. Now it should just use the natural rate if it is not passed in explicitly.
Phil,
