hello guys...
how can i see the streaming of my cameras on zoneminder with my iphone?
there is some software? i can't see streaming from safari (on iphone)
thanks
zoneminder 1.24.2-2 + iphone 3g
Apple: yes you can ZM streaming
I believe that the answer is here:
http://www.zoneminder.com/forums/viewto ... light=ipad
It is the same as the iPad. Safari needs to have the streaming forced and you cannot use cambozola... because it is Java and there is no Java support on iPhone/iPad/iPod-Touch. There is Javascript support but no pure Java.
You need to make these changes to your instalation to make streaming work on the iphone's safari.
http://www.zoneminder.com/forums/viewtopic.php?t=15429
Making those changes might work. But if you can do without cambozola then it seems just setting CAN_STREAM to "yes" and STREAM_METHOD to "jpeg" should work. You also uncheck OPT_CAMBOZOLA and I suggest clearing the text field for PATH_CAMBOZOLA.
I did those things and am getting streaming images across to my iPad and iPhone. These Apple mobile devices do not support JAVA so cambozola will not work... but they do allow for the streaming jpeg but you have to explicitly set the streaming ability as the auto browser streaming capability detection seems to be lacking in the latest release of ZM (1.24.2).
