zmc high cpu usage with nework camera
Posted: Sun Jun 06, 2010 2:12 pm
This seems to be a popular topic.
I am at the point where I think I'm just going to spring for a real DVR for my cameras; have only a 3ghz cpu with only a single PCI slot and maxxed it out with my 4 camera video card - 4 cams at 1fps - so picked up a Pixord network camera on Ebay so to expand the system.
Zoneminder was able to work with the camera, but zmc just drives the system (and me) crazy with it's cpu usage. System has variable speed fans and I can hear them going on and off as ZMC cycles up and down.
Didn't seem to matter if net cam was set to Monitor or Modect.
I disabled the network cam and it's quiet again with my 4 cameras at 1fps.
Will leave the Pixord on, but will just monitor it over network without ZM. Unfortunately, will have to open a port on my Netscreen router.
Have read here where network cameras use considerably more cpu but didn't think it would be so bad.
So.......... since I only use Linux, and Pixord p300 requires Windows activex, is there any way on Linux to just stream the network camera.
Thanks,
Jim
Thanks,
Jim
