windows reinstall and now problem...
hy all, i have zm working for some time now... al works greate...problem is i have reinstaled windows and now i cannot view streaming from camera, or recorded events... there is nothing in logs and i suspect it has to do with firefox, can anyone sugest me a solution or something ? cheers
Are you referring to two separate machines here? One with ZM working and you had access and now with the re installation of windows on the second machine on the same lan and you no longer have access? Or are you referring to one of the ZM VM appliances? Or is this an access via wan issue? In any event, my gut says firewall issue.
i have two machines, one its dedicated for zm and another one for personal use... i have reinstaled the one for personal use... i can access the zm website from zm machine, i can see how many events / day and other stuff but i cannot see streams from the machine... and nothing wrong apears in logs... i suspect firefox.. but have no idea where to start from..
Yup I'm now getting this too, ever since I upgraded to firefox 3.6.3 I cannot view live streams or playback events, I just get a broken image. This is on a v1.24.2 version zonemaster
But if I right click that broken image and say "view image" it works.
Now on my local zoneminder box which is 1.21.4 everything is working.
But there is one big difference between the 2 boxes. the local one is running on port 80 and the remote one is port forwarded internal on port 80 and external on some other port.
Haven't figured this one out yet. So if anyone has any ideas.
-M
-M
