Page 1 of 1
BUG - Archive not working correctly
Posted: Mon Mar 15, 2004 9:42 am
by ajpalm
I've added some items to the archive section in the events area, but now when I click on the archive items to view them, its showing no items in there.....
Bug or user error?
Re: BUG - Archive not working correctly
Posted: Mon Mar 15, 2004 9:55 am
by ajpalm
Ok did some digging and it appears when I click on the archive number (showing how main events are in there, under the main menu) the filter window is showing a wrong filter (using filter 2), but its showing for monitor id 2, but my monitor ids are 3 and 4, and its showing the archive states is equal to 'Unarchived only'.
If I change the monitor ID to 4 (my second camera input) and the status to archived only and then go submit its returns the correct values.
Is it just my setup? It use to work in earlier versions.
Posted: Mon Mar 15, 2004 10:14 am
by zoneminder
Hi Andrew,
Thanks for spotting that. The problem is a 'val1=2' which should be a 'val2=1' on the Archived column column in zm_html_view_console.php if you want to fix it on your install until the next version is ready.
Cheers,
Phil,
Posted: Mon Mar 15, 2004 10:23 am
by ajpalm
Posted: Mon Mar 15, 2004 10:27 am
by ajpalm
No problems... I'll wait for the 1.19 update, as it appears to be out soon. I don't use the archive function very often.
Any idea why the monitor ID is incorrect, as I only have 3 and 4, but its waiting to do 2. Which is the second one in the listing (only showing 3 and 4 of course)
Thanks for your great work!
