Forward Events
r0ck3t
Forward Events
Post by r0ck3t »
Hi!
I would like to "push" all events in realtime to another server for home automation.
My approach was to use a filter running a script to send the events, but the filter seems to run once per minute only and therefore I'm loosing all events in between.
Is there a way to do that?
Thanks!
r0ck3t
Post by r0ck3t »
OK, finally found a way... xAP
Just modified the xAP script to send the events directly to the IP and Port instead of broadcasting them.
