zmu exit status 255, driving me crazy
Posted: Tue Jun 15, 2010 10:23 am
This is a copy of a post I made in the general forums 2.24... but probably should have posted this question here...
Admittedly I'm new to zoneminder, but I spent a great deal of time getting my card so that I can get tvtime and xawtv to display video from my cams. The card is a generic Kodicom 4400r. BUT ZONEMINDER KEEPS EXITING FROM MONITORING, with "exit status 255".
The error log shows...
10-06-14 23:42:45.001518 zmdc[8657].INF [Starting pending process, zmc -d /dev/video0]
10-06-14 23:42:45.002735 zmdc[8657].INF ['zmc -d /dev/video0' starting at 10/06/14 23:42:45, pid = 8695]
10-06-14 23:42:45.025100 zmdc[8657].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
I have zmu output... (check end of message).
I"m running the latest version of Ubuntu, and the video does show in tvtime, and xawtv just fine. I'm running zoneminder 1.24.2build3.
Can anyone provide some suggestions on how to fix this? The card I'm using is the same as .... http://cgi.ebay.ca/120-fps-NTSC-4-chann ... 2307b8586e
PS
...it took some tweaking to get the bttv driver to work with the card... I needed to add the following to a module.conf file...
alias char-major-81 bttv
options bttv card=0x85,0x84,0x85,0x85 radio=-1 tuner=4 pll=0
zmu -q -d /dev/video0 -v
Video Device: /dev/video0
General Capabilities
Driver: bttv
Card: BT878 video (Kodicom 4400R (sla
Bus: PCI:0000:02:0c.0
Version: 0.9.18
Type: 0x5000015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 16
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
...etc
And ... it took some tweaking to get the bttv driver to work with the card... I needed to add the following to a module.conf file...
PS
Driver: bttv
Version: 0.9.18
Type: 0x5000015
Does not have tuner
Does not have radio
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 16
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
...etc
