pclinuxos 2010 - 2.6.32.11-pclos2.bfs #1 SMP PREEMPT Wed Apr 7 13:33:19 CDT 2010 i686 Intel(R) Core(TM)2 Duo CPU P8400 @ 2.26GHz GNU/Linux
Zoneminder 1.24.1 from pclinuxos repository.
It works for half an hour or so and then hangs with no response from
http://127.0.0.1/zm -
I continue to see the camera by looking at its IP address.
Jun 18 12:44:00 localhost zma_m1[3728]: INF [Axis-FD: 34000 - Processing at 30.30 fps]
Jun 18 12:44:32 localhost zmc_m1[3724]: INF [Axis-FD: 35000 - Capturing at 29.41 fps]
Jun 18 12:44:34 localhost zma_m1[3728]: INF [Axis-FD: 35000 - Processing at 29.41 fps]
Jun 18 12:44:57 localhost zmc_m1[3724]: INF [Got signal 11 (Segmentation fault), crashing]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Signal address is 0xdfa9a7dc, from 0x8079215]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Backtrace: /usr/lib/zm/bin/zmc [0x8079215]]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Backtrace: /usr/lib/zm/bin/zmc [0x807a34f]]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Backtrace: /usr/lib/zm/bin/zmc [0x807c17a]]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Backtrace: /usr/lib/zm/bin/zmc [0x806d27a]]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Backtrace: /usr/lib/zm/bin/zmc [0x804d072]]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Backtrace: /lib/i686/libc.so.6(__libc_start_main+0xe6) [0xb67d6a36]]
Jun 18 12:44:57 localhost zmc_m1[3724]: ERR [Backtrace: /usr/lib/zm/bin/zmc(__gxx_personality_v0+0xc9) [0x804c841]]
Jun 18 12:44:57 localhost zmc_m1[3724]: INF [Backtrace complete, please execute the following command for more information]
Jun 18 12:44:57 localhost zmc_m1[3724]: INF [addr2line -e /usr/lib/zm/bin/zmc(__gxx_personality_v0+0xc9) 0x8079215 0x8079215 0x807a34f 0x807c17a 0x806d27a 0x804d072 0xb67d6a36 0x804c841]
Jun 18 12:44:57 localhost zmdc[3692]: ERR ['zmc -m 1' exited abnormally, exit status 11]
Jun 18 12:44:57 localhost zmdc[3692]: INF [Starting pending process, zmc -m 1]
Jun 18 12:44:57 localhost zmdc[3692]: INF ['zmc -m 1' starting at 10/06/18 12:44:57, pid = 6136]
Jun 18 12:44:57 localhost zmdc[6136]: INF ['zmc -m 1' started at 10/06/18 12:44:57]
Jun 18 12:44:57 localhost zmc_m1[6136]: INF [Debug Level = 0, Debug Log = <none>]
Jun 18 12:44:57 localhost zmc_m1[6136]: INF [Starting Capture]
Jun 18 12:44:57 localhost zmc_m1[6136]: ERR [Can't connect to remote camera: Connection refused]
Jun 18 12:44:57 localhost zmc_m1[6136]: ERR [Unable to connect to camera]
Jun 18 12:44:57 localhost zmc_m1[6136]: ERR [Failed to pre-capture monitor 1 (0/1)]
Jun 18 12:44:57 localhost zmdc[3692]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jun 18 12:45:02 localhost zmdc[3692]: INF [Starting pending process, zmc -m 1]
Jun 18 12:45:02 localhost zmdc[3692]: INF ['zmc -m 1' starting at 10/06/18 12:45:02, pid = 6147]
Jun 18 12:45:02 localhost zmdc[6147]: INF ['zmc -m 1' started at 10/06/18 12:45:02]
Jun 18 12:45:02 localhost zmc_m1[6147]: INF [Debug Level = 0, Debug Log = <none>]
Jun 18 12:45:02 localhost zmc_m1[6147]: INF [Starting Capture]
Jun 18 12:45:02 localhost zmc_m1[6147]: ERR [Can't connect to remote camera: Connection refused]
Jun 18 12:45:02 localhost zmc_m1[6147]: ERR [Unable to connect to camera]
Jun 18 12:45:02 localhost zmc_m1[6147]: ERR [Failed to pre-capture monitor 1 (0/1)]
Jun 18 12:45:02 localhost zmdc[3692]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jun 18 12:45:12 localhost zmdc[3692]: INF [Starting pending process, zmc -m 1]
Jun 18 12:45:12 localhost zmdc[3692]: INF ['zmc -m 1' starting at 10/06/18 12:45:12, pid = 6165]
Jun 18 12:45:12 localhost zmdc[6165]: INF ['zmc -m 1' started at 10/06/18 12:45:12]
Jun 18 12:45:12 localhost zmc_m1[6165]: INF [Debug Level = 0, Debug Log = <none>]
Jun 18 12:45:12 localhost zmc_m1[6165]: INF [Starting Capture]
Jun 18 12:45:33 localhost zmc_m1[6165]: ERR [Can't connect to remote camera: Connection timed out]
Jun 18 12:45:33 localhost zmc_m1[6165]: ERR [Unable to connect to camera]
Jun 18 12:45:33 localhost zmc_m1[6165]: ERR [Failed to pre-capture monitor 1 (0/1)]
Jun 18 12:45:33 localhost zmdc[3692]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jun 18 12:45:53 localhost zmdc[3692]: INF [Starting pending process, zmc -m 1]
Jun 18 12:45:53 localhost zmdc[3692]: INF ['zmc -m 1' starting at 10/06/18 12:45:53, pid = 6235]
Jun 18 12:45:53 localhost zmdc[6235]: INF ['zmc -m 1' started at 10/06/18 12:45:53]
Jun 18 12:45:53 localhost zmc_m1[6235]: INF [Debug Level = 0, Debug Log = <none>]
Jun 18 12:45:53 localhost zmc_m1[6235]: INF [Starting Capture]
Jun 18 12:45:53 localhost zmc_m1[6235]: ERR [Invalid response status 401: Unauthorized]
Jun 18 12:45:53 localhost zmc_m1[6235]: ERR [Unable to get response]
Jun 18 12:45:53 localhost zmc_m1[6235]: ERR [Failed to capture image from monitor 1 (0/1)]
Jun 18 12:45:53 localhost zmdc[3692]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Jun 18 12:46:27 localhost zmdc[3692]: INF [Starting pending process, zmfilter.pl]
Jun 18 12:46:27 localhost zmdc[3692]: INF ['zmfilter.pl' starting at 10/06/18 12:46:27, pid = 6301]
Jun 18 12:46:27 localhost zmdc[6301]: INF ['zmfilter.pl' started at 10/06/18 12:46:27]
Jun 18 12:46:27 localhost zmfilter[6301]: INF [Scanning for events]
Jun 18 12:46:32 localhost zmdc[3692]: ERR ['zmfilter.pl ' exited abnormally, exit status 9]
Jun 18 12:46:33 localhost zmdc[3692]: INF [Starting pending process, zmc -m 1]
Jun 18 12:46:33 localhost zmdc[6313]: INF ['zmc -m 1' started at 10/06/18 12:46:33]
Jun 18 12:46:33 localhost zmdc[3692]: INF ['zmc -m 1' starting at 10/06/18 12:46:33, pid = 6313]
Jun 18 12:46:33 localhost zmc_m1[6313]: INF [Debug Level = 0, Debug Log = <none>]
Jun 18 12:46:33 localhost zmc_m1[6313]: INF [Starting Capture]
Jun 18 12:46:33 localhost zmc_m1[6313]: ERR [Invalid response status 401: Unauthorized]
Jun 18 12:46:33 localhost zmc_m1[6313]: ERR [Unable to get response]
Jun 18 12:46:33 localhost zmc_m1[6313]: ERR [Failed to capture image from monitor 1 (0/1)]
Jun 18 12:46:33 localhost zmdc[3692]: ERR ['zmc -m 1' exited abnormally, exit status 255]
