Page 1 of 1
Troubles with ACTi-7411
Posted: Mon Jun 21, 2010 2:11 am
by dgrierms
Update: Found that patch, but can't get it to install. I don't have a base "build" directory because I didn't build from source, I installed using Synaptic package manager. Any suggestions?
Hello all,
I've been tinkering for the past few days to get ZM working with an ACTi-7411.
I unearthed a few threads with some useful information.
http://www.zoneminder.com/forums/viewtopic.php?t=12344 -- configuration of acti cameras
http://www.zoneminder.com/forums/viewto ... light=acti -- a poster named "Exno" is using the exact same camera so I know it is possible.
I've followed the directions as described, but ZoneMinder displays a 640x480 outline with the famous "Red X".
Here are my thoughts: ffmpeg works
ffmpeg -i http://eng@192.168.1.19/cgi-bin/cmd/encoder?GET_STREAM ./test.avi
This produces a legit file.
Apache error log is full of stuff, but I don't know what any of it means, so I suspect that is the problem. I keep hearing about an "ffmpeg authentication patch", but after a day of looking for it I've had no success. Maybe that would do the trick? Can someone post a link to that?
Apache2 error log:
[Sun Jun 20 14:35:32 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/options.php on line 193, referer: http://192.168.0.5/zm/index.php?view=options
[Sun Jun 20 14:35:41 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 14:35:41 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:41:00 2010] [error] [client 127.0.0.1] File does not exist: /var/www/crossdomain.xml
[Sun Jun 20 15:49:07 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:07 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:49:15 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:49:18 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:18 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:49:31 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:49:34 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:34 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:49:56 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:49:56 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:50:01 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:50:23 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:50:23 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:50:50 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:53:58 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:56:28 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:56:32 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:56:32 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:56:59 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:57:02 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 15:57:02 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 15:57:13 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 15:57:19 2010] [error] [client 192.168.0.9] socket_sendto( /tmp/zms-814575s.sock ) failed: No such file or directory, referer: http://192.168.0.5/zm/index.php?view=watch&mid=1
[Sun Jun 20 15:57:19 2010] [error] [client 192.168.0.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-814575s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.0.5/zm/index.php?view=watch&mid=1
[Sun Jun 20 16:15:00 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 16:16:17 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 16:16:17 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
sh: arp: not found
[Sun Jun 20 16:16:39 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 16:16:39 2010] [error] [client 192.168.0.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
sh: arp: not found
[Sun Jun 20 16:26:23 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 16:27:18 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 16:31:56 2010] [notice] Graceful restart requested, doing restart
apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1 for ServerName
[Sun Jun 20 16:31:56 2010] [notice] Apache/2.2.14 (Ubuntu) PHP/5.3.2-1ubuntu4.2 with Suhosin-Patch configured -- resuming normal operations
[Sun Jun 20 16:32:15 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:27:27 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:27:37 2010] [error] [client 192.168.0.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:32:51 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:32:51 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 19:32:59 2010] [error] [client 192.168.1.9] File does not exist: /var/www/favicon.ico
[Sun Jun 20 19:33:03 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:33:07 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:33:07 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 19:39:13 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:39:18 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:18 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:31 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:31 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:44 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:44 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:58 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:39:58 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:11 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:11 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:24 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:24 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:37 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:37 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:50 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:40:50 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:03 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:03 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:16 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:16 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:29 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:29 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:42 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:42 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:55 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:41:55 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:08 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:08 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:21 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:21 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:34 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:34 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:47 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:42:47 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-762694s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:44:15 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:44:15 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
[Sun Jun 20 19:44:26 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:50:13 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:50:13 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 813, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 818, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 823, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:19 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 828, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:26 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-298733s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:51:26 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-298733s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 813, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 818, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 823, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:30 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 828, referer: http://192.168.1.103/zm/index.php
[Sun Jun 20 19:51:35 2010] [error] [client 192.168.1.9] socket_sendto( /tmp/zms-739523s.sock ) failed: No such file or directory, referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:51:35 2010] [error] [client 192.168.1.9] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-739523s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.103/zm/index.php?view=watch&mid=1
[Sun Jun 20 19:52:37 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:53:07 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:53:10 2010] [error] [client 192.168.1.9] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808
[Sun Jun 20 19:53:22 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 129
[Sun Jun 20 19:53:22 2010] [error] [client 192.168.1.9] PHP Deprecated: Function split() is deprecated in /usr/share/zoneminder/skins/classic/views/monitor.php on line 551
sh: arp: not found
Some of the error log removed because it was too long, but these same errors kept showing up over and over again.
I hope I've included enough info on this post to be hopeful. Didn't want to be "that guy" posting "OMG help it does not work fix it!!11"
Posted: Tue Jun 29, 2010 1:45 pm
by MythosGR
I have the same problem with a Vivotek 7361 on Ubuntu server 10.4.
Did you manage to get it working?
Posted: Wed Nov 10, 2010 3:46 am
by DaveQB
It looks like the php version you are running is not what Zoneminder expected.
I'd say tackle that problem first, then see what issues are left in the logs.
NB: What version of php it wants, I am not sure sorry. Will need to look that up.
Posted: Wed Nov 10, 2010 7:19 am
by Flash_
The php errors can be ignored. If they're annoying you can change the php loglevel (just google that message, the distro changes to php5 have caused this in many apps, not just zm)
Posted: Wed Nov 10, 2010 7:24 am
by DaveQB
Yes I have seen those errors before migrating web sites.
I thought I only got warnings not errors, thus my conclusion it could be the cause of some issues.
Posted: Fri Nov 12, 2010 8:37 pm
by TechGuy
How about permissions on /tmp
perhaps apache doesn't have permissions to create files in the /tmp directory
Posted: Tue Dec 28, 2010 6:01 pm
by insippo
how to fix this error?
