Page 1 of 1
Axis 216MFD no stream in ZM
Posted: Thu Jun 24, 2010 4:51 pm
by subliminal_boy_9
Hey all -
Long time since my last checkin. ZM has been quietly doing it's job for a long time.
I've recently moved to a new server. ZM is installed, and apparently happy. I have a new set of cameras to install, all Axis IP cams in this case.
The first test cam is a 216MFD. I can get image in anonymous mode from the camera via firefox. ZM can't see an image, however. I've set kernel.shmall and shmmax as they should be per the wiki, and verified the path from the camera to be correct.
Any ideas?
Posted: Thu Jun 24, 2010 5:28 pm
by kingofkya
check for typos that model worked fine i have used it before.
Also after you set shared memory did you reboot?
Posted: Thu Jun 24, 2010 7:46 pm
by subliminal_boy_9
kingofkya wrote:check for typos that model worked fine i have used it before.
Yes, rebooted. No typos that I can find. :( I want it to be that easy.
Posted: Thu Jun 24, 2010 8:11 pm
by subliminal_boy_9
Other info:
Firmware on camera: 4.47 (current)
OS: Ubuntu 10.4
Logs: clear of errors
