Place the code in a file named "ABS_MegaCam.pm" and add it with the rest of the ZoneMinder Control Perl libraries (mine are in
/usr/local/share/perl/5.10.1/ZoneMinder/Control)the exact location depends on the distro.
# ZoneMinder ABS MegaCam Control Protocol Module, $Date: 2010-06-25
# This module contains the implementation of the ABS MegaCam camera control protocol.
# MegaCam 4210, MegaCam 4220
# And possibly MegaCam 421M and MegaCam 422M (not tested but they all use the same Firmware for MegaCam Series)
package ZoneMinder::Control::ABS_MegaCam;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# ABS MegaCam Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub moveMap
my $self = shift;
my $params = shift;
my $xcoord = $self->getParam( $params, 'xcoord' );
my $ycoord = $self->getParam( $params, 'ycoord' );
Debug( "Move Map to $xcoord,$ycoord" );
my $cmd = "/ptz.cgi?center=$xcoord,$ycoord&imagewidth=".$self->{Monitor}->{Width}."&imageheight=".$self->{Monitor}->{Height};
$self->sendCmd( $cmd );
sub moveRelUp
my $self = shift;
my $params = shift;
my $tiltstep = $self->getParam( $params, 'tiltstep' );
Debug( "Move Up - TiltStep $tiltstep" );
my $cmd = "/ptz.cgi?move=up&speed=$tiltstep";
sub moveRelDown
my $self = shift;
my $params = shift;
Debug( "Move Down - TiltStep $tiltstep" );
my $cmd = "/ptz.cgi?move=down&speed=$tiltstep";
sub moveRelLeft
my $self = shift;
my $params = shift;
my $panstep = $self->getParam( $params, 'panstep' );
Debug( "Move Left - PanStep $panstep" );
my $cmd = "/ptz.cgi?move=left&speed=$panstep";
sub moveRelRight
my $self = shift;
my $params = shift;
Debug( "Move Right - PanStep $panstep" );
my $cmd = "/ptz.cgi?move=right&speed=$panstep";
sub moveRelUpRight
my $self = shift;
my $params = shift;
Debug( "Move Up/Right - PanStep $panstep" );
my $cmd = "/ptz.cgi?move=rightup&speed=$panstep";
sub moveRelUpLeft
my $self = shift;
my $params = shift;
Debug( "Move Up/Left - PanStep $panstep" );
my $cmd = "/ptz.cgi?move=leftup&speed=$panstep";
sub moveRelDownRight
my $self = shift;
my $params = shift;
Debug( "Move Down/Right - PanStep $panstep" );
my $cmd = "/ptz.cgi?move=rightdown&speed=$panstep";
sub moveRelDownLeft
my $self = shift;
my $params = shift;
Debug( "Move Down/Left - PanStep $panstep" );
my $cmd = "/ptz.cgi?move=leftdown&speed=$panstep";
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "/ptzconfig.cgi?setserverpresetname=$preset";
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "/ptz.cgi?gotoserverpresetname=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "/ptz.cgi?move=home&speed=1";
1;
__END__
On the new window "Control Capabilities" Click "Add New Control"
Main Tab:
Type: Remote
Protocol: ABS_MegaCam
Move Tab:
Can Move: check
Can Move Diagonally: check
Can Move Mapped: check
Can Move Relative: check
Pan Tab:
Can Pan: check
Min Pan Step: 0
Max Pan Step: 10 (adjust to your needs. If you feel the need it will go as high as 100)
Tilt Tab:
Can Tilt: check
Min Tilt Step: 0
Max Tilt Step: 10 (adjust to your needs. If you feel the need it will go as high as 100)
Presets tab:
Has Presets: check
Num Presets: 10
Has Home Preset: check (for this to work you have to select a home preset on the cameras main home page)
Can Set Presets: check
When done click "save" and refresh the "Control Capabilities" window, and then close.
At your monitor window, refresh it and from the pull-down menu at "Control Type" select "ABS MegaCam"
complete the rest and when done click "save":
Controllable: check
Control Type: ABS MegaCam
Control Device: leave blank
Control Address: user:pass@cameraIP
